ProTrinket Problems
Re: ProTrinket Problems
by adafruit_support_rick on Wed Oct 08, 2014 5:27 pm
What does the Pro Trinket show up as in Device Manager?
by chasirish on Wed Oct 08, 2014 5:36 pm
[quote="Virgil_Machine"]I have the same problem, same message. 3V Pro Trinket delivered yesterday.
/quote]
Mine is the 5v version. Try changing the blink code's timing. Mine worked at first, but after changing the timing, it gave the same error.
chasirish
by Virgil_Machine on Wed Oct 08, 2014 5:49 pm
USBTiny
Blink works---it uploaded successfully twice--the only 2 times it has uploaded. Changing the timing won't help if I can't upload, but I know it's working.
Virgil_Machine
by adafruit_support_rick on Wed Oct 08, 2014 6:54 pm
And you're getting the rc=-1 error? Or are you getting "expected 4, got -5" errors?
You've got the driver installed, so there's no point in reinstalling that anymore.
Are you sure the red LED is still pulsing when the upload actually starts?
by Virgil_Machine on Wed Oct 08, 2014 7:42 pm
I'm getting the message that was posted by OP
Virgil_Machine
by Virgil_Machine on Wed Oct 08, 2014 8:23 pm
Actually, since the device disappears from device manager, and can't be found, and at other times shows up with the yellow triangle/exclamation point, I need to remove it and reinstall until it shows up as working properly--which of course it doesn't.
Something is wrong. It may be me, but I have no clue what it is.
Virgil_Machine
by chasirish on Wed Oct 08, 2014 8:28 pm
My driver's installed correctly and I'm still getting the error
chasirish
by adafruit_support_rick on Thu Oct 09, 2014 6:37 am
Virgil_Machine wrote:I'm getting the message that was posted by OP
Have you tried a different USB cable, different USB port? Also try connecting through a self-powered hub.
by Virgil_Machine on Thu Oct 09, 2014 7:30 am
Different cable, different port--no change. Self-powered hub--I have one, but I have to look for a cable to connect it to the PC. I'll only do that if you explain why that should make a difference...or are you guessing? Do you have other examples where symptoms were similar to ours were solved by a powered hub?
Virgil_Machine
by adafruit_support_rick on Thu Oct 09, 2014 8:25 am
We've seen problems with USB3.0 ports with Gemma and Trinket. In general, though, the hub changes the timing, and this appears to be either a timing or a connection problem.
by Virgil_Machine on Thu Oct 09, 2014 9:11 am
Thank you. I realized after my last post that I sounded cranky--I apologize..
This is a ProTrinket on USB 2.0 not a gemma or trinket on USB 3.0.
I have 3V and 5V ProTrinkets coming today. I'll try those. I'll let you know if the powered hub works once I figure out where I repurposed the USB A/A cable.
FYI, my UNO and Pro Mini have no problems connecting to the IDE on this computer.
Virgil_Machine
by Virgil_Machine on Thu Oct 09, 2014 9:22 am
Found a cable for the powered hub. Windows does not even recognize that new hardware is attached.
Tonight I'll fire up a Windows 7 machine and try that.
Sounds like a product problem
Virgil_Machine
by adafruit_support_rick on Thu Oct 09, 2014 9:24 am
The Pro Trinket uses a similar bootloader to the Trinket and Gemma.
And, yes, I am guessing. ;) You and chasirish have the only problem like this that I've seen.
by Virgil_Machine on Thu Oct 09, 2014 7:10 pm
I'm ready to call this a product problem.
I received a new Pro Trinket this afternoon. It functions the same way as the other one, Windows 8.1 and Windows 7 machines. Multiple cables and ports. Not recognized through the powered USB hub on either machine.
I was able to upload Blink once (and only once) I changed the timing, and the execution showed that--so I know it worked. I have not been able to upload anything else. Device recognition is flaky to say the least: sometimes not recognized, sometimes shown as not functioning, sometimes the driver won't install, sometimes when I press reset the device disappears and I have to reconnect the USB cable an least twice to get it back.
Another user has the same problem.
Unless you have a solution, I need a refund for 3 Pro Trinkets. This is really disappointing.
Virgil_Machine
by Virgil_Machine on Fri Oct 10, 2014 10:20 am
OK. My Windows 8.1 machine is a dual boot with Ubuntu 12.04. So, I booted into Ubuntu and it works there.
I have not tried the 5V yet, but at least 1 of the 3Vs works. (This was a pain, because I have not been using this machine for Arduino development--had to download the IDE, and some additional libraries. But I got it to work.)
So, it appears that Adafruit has a problem with Pro Trinkets on Windows 8.1 and Windows 7, at least. This may be limited to certain hardware. The Win8.1 machine is an self built with an AMD dual-core 64-bit machine (because it's dual-boot, that's the same as the Ubuntu). The Win7 is an older Lenovo with an Intel dual-core 64-bit processor.
True, only 2 people have reported this problem, but the ProTrinket is fairly new and was out of stock for a while. I suggest that you to some thorough testing on Windows.
Virgil_Machine
