Pro Trinket Bootloader Problem
Re: Pro Trinket Bootloader Problem
by Ronfinlay on Sun Jul 09, 2017 12:47 pm
I bought a Micro USB cable and told the person at Staples (business supply store in Canada) I need a data cable. I allowed my to try one, and the red LED faded on and off slowly, so while not the double fast blink, my MacBook running the IDE still reports "An error occurred uploading the sketch." I would appreciate any further ideas. This has me totally stumped. I can't even get the blink sketch to work. Is there some other setting in Arduino or on the Mac I need to address? Thanks for being there.
Ronfinlay
by adafruit_support_rick on Sun Jul 09, 2017 1:15 pm
Much better. fading in and out means that the bootloader is running. The bootloader runs for about 10 seconds, and the upload *must* begin during that time. So, start your compile, then press the reset button so that the led is fading in and out when the upload begins. You may have to work on the timing a bit.
by Ronfinlay on Sun Jul 09, 2017 1:20 pm
Hi Again. So I plugged the trinket in. Fading Red. Pressed reset and within 2 seconds clicked upload (Blink Sketch). Same error.
Ronfinlay
by Ronfinlay on Sun Jul 09, 2017 1:24 pm
Also, keep in mind, it's the standard Blink Sketch on the arduino.cc/ examples.... Is there anything I need to change to run that on the Trinket?
Ronfinlay
by adafruit_support_rick on Sun Jul 09, 2017 1:28 pm
No changes necessary.
Go into Arduino Preferences and check the boxes for verbose on upload and compile. Copy and paste the trace from the sketch window here.
Also, does the Pro trinket show up under USB in the Mac System Report?
by Ronfinlay on Sun Jul 09, 2017 1:34 pm
Thank for staying with me on this. First, do you want me to paste the verbose error messages in this box? I know there's a rule about not posting code, probably since it can be so long. Please clarify.
As for the mac system report, I don't know what that means or where to look. I assume in system preferences. Please offer any suggestions. Thanks
Ronfinlay
by adafruit_support_rick on Sun Jul 09, 2017 1:38 pm
Yes, paste the trace here. Click the </> button above the window, and paste the trace between the [CODE] tags.
Go into the Apple menu, select About this Mac.... In the box that comes up will be a button for System Report.
In System report, on the left-hand side, you'll see a line that says USB. Click that, and it will show you all the USB devices on your computer. One of them should be the Pro Trinket
by Ronfinlay on Sun Jul 09, 2017 1:45 pm
Here it is. I've attached a screen shot of the mac systems report. USB tiny, but no mention of Pro Trinket. Thanks again
Arduino: 1.8.1 (Mac OS X), Board: "Pro Trinket 5V/16MHz (USB)"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/ronfinlay1/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/ronfinlay1/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/ronfinlay1/Documents/Arduino/libraries -fqbn=adafruit:avr:protrinket5 -ide-version=10801 -build-path /var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/ronfinlay1/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/ronfinlay1/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/ronfinlay1/Documents/Arduino/libraries -fqbn=adafruit:avr:protrinket5 -ide-version=10801 -build-path /var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
Using board 'protrinket5' from platform in folder: /Users/ronfinlay1/Library/Arduino15/packages/adafruit/hardware/avr/1.4.9
Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/sketch/Blink.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/sketch/Blink.ino.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/sketch/Blink.ino.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/sketch/Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/wiring_pulse.S" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_pulse.S.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/WInterrupts.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/hooks.c" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/hooks.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/wiring.c" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/wiring_analog.c" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_analog.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/wiring_digital.c" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_digital.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/wiring_pulse.c" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_pulse.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/wiring_shift.c" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_shift.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/CDC.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/CDC.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/HardwareSerial.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/HardwareSerial0.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial0.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/HardwareSerial1.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial1.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/HardwareSerial2.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial2.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/HardwareSerial3.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial3.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/IPAddress.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/IPAddress.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/PluggableUSB.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/PluggableUSB.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Print.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/Print.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Stream.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/Stream.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Tone.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/Tone.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/USBCore.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/USBCore.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WMath.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/WMath.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WString.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/WString.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/abi.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/abi.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/main.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/main.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/new.cpp" -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/new.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_pulse.S.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/WInterrupts.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/hooks.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_analog.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_digital.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_pulse.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/wiring_shift.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/CDC.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial0.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial1.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial2.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/HardwareSerial3.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/IPAddress.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/PluggableUSB.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/Print.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/Stream.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/Tone.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/USBCore.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/WMath.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/WString.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/abi.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/main.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/new.cpp.o"
Linking everything together...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/Blink.ino.elf" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/sketch/Blink.ino.cpp.o" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/core/core.a" "-L/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004" -lm
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/Blink.ino.elf" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/Blink.ino.eep"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom  "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/Blink.ino.elf" "/var/folders/lq/2t0vyq_j001418csm6hnb_l80000gp/T/arduino_build_777004/Blink.ino.hex"
Sketch uses 928 bytes (3%) of program storage space. Maximum is 28672 bytes.
Global variables use 9 bytes of dynamic memory.
An error occurred while uploading the sketch
Invalid library found in /Users/ronfinlay1/Documents/Arduino/libraries/examples: /Users/ronfinlay1/Documents/Arduino/libraries/examples
Invalid library found in /Users/ronfinlay1/Documents/Arduino/libraries/ScreenTest0325V3: /Users/ronfinlay1/Documents/Arduino/libraries/ScreenTest0325V3
Invalid library found in /Users/ronfinlay1/Documents/Arduino/libraries/ScreenTest0328V1: /Users/ronfinlay1/Documents/Arduino/libraries/ScreenTest0328V1
Mac System Report USB.png (161.19 KiB) Viewed 868 times
Last edited by adafruit_support_rick on Sun Jul 09, 2017 4:23 pm, edited 1 time in total.
Reason: please use code tags when posting code (</> button above edit window)
Ronfinlay
by Ronfinlay on Sun Jul 09, 2017 1:57 pm
Sorry, didn't follow you. Now I see what you meant.
Compiling sketch...
Compiling core...
Ronfinlay
by Ronfinlay on Sun Jul 09, 2017 2:07 pm
I clicked on the system report again, and on USB Tiny. Attached is recognition of something from Adafruit, but not so specific as Trinket. I hope this helps you help me, with thanks.
Mac USB report showing Adafruit.png (27.18 KiB) Viewed 856 times
Ronfinlay
by adafruit_support_rick on Sun Jul 09, 2017 4:31 pm
Yeah - USBtiny is the right thing
Looks like you didn't check the box for verbose on upload in Arduino preferences. Can you do that and post the trace again?
Also, make sure the programmer is is set to USBtinyISP in the Tools menu
by Ronfinlay on Sun Jul 09, 2017 5:29 pm
Wow. I
m amazed. Thank you so much. Did the Tools menu USB Tiny ISP and it worked. Blink responds to changes in delay times, so that seems to work. My other sketch uploaded, so that's encouraging. Looks like no need to send the verbose error stuff, for now.
Thank you so much. Tomorrow is going to be a great day.
I really appreciate your kindness
Ronfinlay
by Ronfinlay on Sun Jul 09, 2017 6:07 pm
Sorry, Just another question. Clearly you know this stuff inside out. My project involves a trinket running three neo pixel rings. Once I program the trinket, I no longer need the MicroUSB cable. I want to power the trinket from it's 5V pin and of course ground. Is there a problem plugging in the Micro USB while the trinket is powered by its on board 5V pin from an external power supply? I'd hate to blow it up. Or do I need to program it, disconnect the USB thereby powering down, then power up with the 5V .... Seems awkward. Thanks again.
Ronfinlay
Ronfinlay
by adafruit_support_rick on Mon Jul 10, 2017 7:34 am
There's a diode on the USB power, so there's no problem plugging it in while 5V is connected.
