Problem with Gemma 2 and USBtinyISP
USB AVR Programmer and SPI interface. Adafruit's USBtinyISP.
leon_stein
Post by leon_stein »
i'm trying to programm my new Gemma 2. i've followed the guide of Gemma 2, but stil get problem/error, that not in your guide.
i try to update this "empty" code to Gemma2
  // put your setup code here, to run once:
  // put your main code here, to run repeatedly:
but get this error:
avrdude: error: usbtiny_transmit:
         this check.
in cmd with
avrdude -c usbtiny -p attiny85 -F
i get this information:
avrdude: error: usbtiny_transmit: usb_control_msg: sending control message faile
d, win error: Ein an das System angeschlossenes Gerõt funktioniert nicht.
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATtiny85 is 1E 93 0B
avrdude done.  Thank you.
does someone know what's happend? how can i solve that?
btw:
window 7
Arduino 1.6.5
avrdude is 5.11
adafruit_support_rick
Re: Problem with Gemma 2 and USBtinyISP
Post by adafruit_support_rick »
avrdude is not communicating with the Gemma. Try some different USB cables and a different USB port.
This is Windows? Does the Gemma show up in Device Manager under Win32-LibUSB Devices?
Franklin97355
Post by Franklin97355 »
Are you pressing the reset button so the LED is flashing while the IDE is trying to upload? If you haven't already check this out. https://learn.adafruit.com/introducing- ... rduino-ide
leon_stein
i've got it now. thanks!!
Return to “USBtinyISP”
