Cannot program trinket pro 5v on Windows 10
by nobdoor on Tue Jun 07, 2016 8:46 pm
Hi all. First, thank you for the active support that's given by adafruit. It is tremendous.
I am currently unable to write the blink program to my Trinket Pro 5V, 16MHz. I've followed the instructions outlined by tdicola here: https://forums.adafruit.com/viewtopic.php?f=20&t=78892, which include installing the USBTiny windows driver, installing the Arduino IDE (1.6.8), and the board/board manager settings for Adafruit.
After initializing the bootloader and uploading the blink sketch, the Trinket-Pro stops pulsing its red LED and idles, with the green LED on. There is minimal information posted in the console after the upload completes. Screenshot shown below. After resetting or reissuing power, the bootloader pulse will activate.
I've also tried this with avrdude after following the steps in the tutorial here: https://learn.adafruit.com/introducing-trinket/programming-with-avrdude. I see similar behavior from the device as with the arduino IDE. However there is a diagnostic that reports that I have the wrong device signature. I have the same behavior with avrdude on Mac as well. My console output is below. Any help is much appreciated. Thank you!
PS - I have also tried hard-coding the avrdude.conf file so that the device signature in the ATtiny85 section matches that of my Trinket-Pro. I have also tried multiple micro-USB cables, and different USB port types (2.0/3.0). No luck.
C:\Users\scott\Downloads>avrdude -F -c usbtiny -p attiny85 -U flash:w:trinketblink.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e950f
avrdude: Expected signature for ATtiny85 is 1E 93 0B
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: current erase-rewrite cycle count is -33686019 (if being tracked)
avrdude: erasing chip
avrdude: reading input file "trinketblink.hex"
avrdude: input file trinketblink.hex auto detected as Intel Hex
avrdude: writing flash (832 bytes):
Writing | ################################################## | 100% 0.68s
avrdude: 832 bytes of flash written
avrdude: verifying flash memory against trinketblink.hex:
avrdude: load data flash data from input file trinketblink.hex:
avrdude: input file trinketblink.hex contains 832 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.11s
avrdude: verifying ...
avrdude: 832 bytes of flash verified
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
nobdoor
Re: Cannot program trinket pro 5v on Windows 10
by franklin97355 on Tue Jun 07, 2016 9:31 pm
Pro Trinkets are not ATtiny85's but ATMega328's https://learn.adafruit.com/introducing-pro-trinket/overview Set your IDE to verbose mode in the File Preferences and post the results.
franklin97355
