Raspberry Pi Zero W not booting
by mhazrat on Mon Mar 20, 2017 5:54 pm
It's not powering up. I don't want to return, I want to exchange for working one!
Yes I did plug in the power and HDMI correctly. I saw the LED light up and started loading the preinstalled SD card for 10 seconds then just went blank. Now there is no response or LED lighting up.
mhazrat
Re: Raspberry Pi Zero W not booting
by adafruit_support_carter on Mon Mar 20, 2017 5:57 pm
What have you done so far to try and get it working? (nvm. info added to original post)
What operating system are you using? What is the HDMI display?
by mhazrat on Mon Mar 20, 2017 6:02 pm
It is my living room TV with HDMI adapter to mini. My laptop has Win10 but I just tried the preloaded SD card it came with. It seemed to be loading fine for first few seconds.
mhazrat
by adafruit_support_carter on Mon Mar 20, 2017 6:12 pm
Try reimaging the SD card with a fresh install of NooBs downloaded from here:
https://www.raspberrypi.org/downloads/
The Pi Zero W requires an image update that didn't get put on the pre-packaged SD cards:
viewtopic.php?f=50&t=113576#p568501
by WA9LT on Thu Mar 23, 2017 4:06 pm
I had the same problem and reimaging the SD card with a fresh install of NooBs works.
WA9LT
