Help getting started with Flora
by Panagiotis_K87 on Sun Dec 02, 2018 2:46 pm
Hello everyone,
I want to try experimenting with Adafruit's Flora(bought the starter kit).
Is there a guide/tutorial on how to start learning from scratch?
I installed arduino software and connected Flora but could not figure out much
from the information i found.
Thank you in advance,any help would be grateful!
Panagiotis_K87
Re: Help getting started with Flora
by kcl1s on Sun Dec 02, 2018 10:06 pm
This getting started with Flora tutorial linked to on the Flora product page should get you going and even has some example projects listed. https://learn.adafruit.com/getting-started-with-flora/overview
Fellow hobbyist
Keith
kcl1s
by adafruit_support_carter on Tue Dec 04, 2018 3:24 pm
The guide linked above is an excellent start. Also look through other guides and projects that use Flora:
https://learn.adafruit.com/search?q=flora
There's also a book:
https://www.adafruit.com/product/1839
by Panagiotis_K87 on Thu Dec 13, 2018 3:11 pm
Thank you very much!
Panagiotis_K87
by Panagiotis_K87 on Sun Dec 16, 2018 12:43 pm
The first link from Keith has no drivers for Flora.
In order to install those drivers(flora),the only way is via codebender?
I am trying that but the file i download it appears as a trojan horse and does not work.
Panagiotis_K87
by adafruit_support_carter on Mon Dec 17, 2018 1:02 pm
The drivers should be available via the link box on this page:
https://learn.adafruit.com/getting-star ... dows-setup
Here's the direct link in case it's not working for you for some reason:
https://github.com/adafruit/Adafruit_Wi ... .3.3.0.exe
