Help getting started with Flora
by Panagiotis_K87 on Sun Dec 02, 2018 2:46 pm
Hello everyone,
I want to try experimenting with Adafruit's Flora(bought the starter kit).
Is there a guide/tutorial on how to start learning from scratch?
I installed arduino software and connected Flora but could not figure out much
from the information i found.
Thank you in advance,any help would be grateful!
Panagiotis_K87
Re: Help getting started with Flora
by kcl1s on Sun Dec 02, 2018 10:06 pm
This getting started with Flora tutorial linked to on the Flora product page should get you going and even has some example projects listed. https://learn.adafruit.com/getting-started-with-flora/overview
Fellow hobbyist
Keith
kcl1s
by adafruit_support_carter on Tue Dec 04, 2018 3:24 pm
The guide linked above is an excellent start. Also look through other guides and projects that use Flora:
https://learn.adafruit.com/search?q=flora
There's also a book:
https://www.adafruit.com/product/1839
by Panagiotis_K87 on Thu Dec 13, 2018 3:11 pm
Thank you very much!
Panagiotis_K87
by Panagiotis_K87 on Sun Dec 16, 2018 12:43 pm
The first link from Keith has no drivers for Flora.
In order to install those drivers(flora),the only way is via codebender?
I am trying that but the file i download it appears as a trojan horse and does not work.
Panagiotis_K87
by adafruit_support_carter on Mon Dec 17, 2018 1:02 pm
The drivers should be available via the link box on this page:
https://learn.adafruit.com/getting-star ... dows-setup
Here's the direct link in case it's not working for you for some reason:
https://github.com/adafruit/Adafruit_Wi ... .3.3.0.exe
by AHIL on Mon Jul 15, 2019 11:36 pm
Greetings. I purchased 50 Adafruit Flora main boards for a summer camp workshops. unfortunately, I cannot seem to find sample projects for just the main board. All the projects that are online references additional components needed. Please help.
The purpose for purchasing the 50 was to include them on tee shirt images that the students will design.
Thank you.
JJ
AHIL
by adafruit_support_carter on Tue Jul 16, 2019 12:04 pm
The FLORA was meant to be used in conjunction with additional items attached to its pads. Other than a status RGB LED, there's not much on the board itself other than then main chip.
If you wanted a more stand alone board, the Circuit Playground Express might be what you are looking for?
https://www.adafruit.com/product/3333
They look similar - round boards with pads. But the Circuit Playground Express is much different, it includes numerous on board hardware items like sensors and buttons that can be used for projects without any external hardware:
https://learn.adafruit.com/adafruit-cir ... uided-tour
by AHIL on Tue Jul 16, 2019 12:33 pm
adafruit_support_carter wrote:The FLORA was meant to be used in conjunction with additional items attached to its pads. Other than a status RGB LED, there's not much on the board itself other than then main chip.
Thank you for the response.
That's very unfortunate. I have 35 Flora main board USB connection that are not recognized. If I can get that particular problem resolved, I will used the boards with attachments later.
AHIL
by adafruit_support_carter on Tue Jul 16, 2019 12:47 pm
OK, please start a new thread for this issue and we can work it there.
