I'm on circ-13 of the "Experimenter's Guide for Arduino" and looking forward to my certificate of completion/UNO degree when I nail this one (I'll make that myself).
The result I'm getting is an LED that's on 100% of the time, and the serial monitor is showing a value of
I've rewired this a couple of times. That doesn't seem to solve it. I've also taken a multimeter to the FSR. it seems to give values that you would expect (high resistance for no pressure and decreasing resistance as pressure is applied).
circ-13_ pressure sensor- no reading
- Franklin97355
Re: circ-13_ pressure sensor- no reading
Post some photos of your circuit and, if you modified the code at all, your code. We'll take a look.
- jim_lucas
I've attached a photo of the circuit.
Here's the code (I changed the variable names slightly because I tried to do 2 sensors right out of the gate- when that didn't work I went back to sensor):
int sensePin1=2;
int ledPin1=9;
Serial.begin(9600);
pinMode(ledPin1,OUTPUT);
int value1 = analogRead(sensePin1)/4;
analogWrite(ledPin1,value1);
Serial.println(value1);
Note: I forgot to say the value I was getting from the serial port. It started at about 112, and then stabilized at about 86.
Also note: I tried changing the resistor value that goes from FSR. I tried 1K and 5K. That didn't do anything.
int sensePin1=2;
int ledPin1=9;
Serial.begin(9600);
You are missing the connection from the FSR to analog pin 2. The analog value is 'floating', since there is no connection to the pin.
- jim_lucas
You're right... I adjusted and it worked. I really appreciate you reviewing and helping out.
. . . . <= tears of thankfulness, dissipated hopelessness and released frustration.
Awesome! Happy to help. :)
