๐ŸŽ„โ›„โ„๏ธ๐ŸŽ It's beginning to look a lot like ADABOX-mas! The next ADABOX from Adafruit ships soon! Get yours now, or give as a gift! ๐ŸŽ„โ›„โ„๏ธ๐ŸŽ
Couple of basic setup questions re the ARDX kit
by frank23 on Fri Mar 03, 2017 10:01 pm
I just received one of the ARDX kits, and had a couple of questions about basic setup:
-- The acrylic mounting plate that the Arduino and the breadboard go on isn't quite like the one pictured in the manual -- it's more like a mirror image. Am I right in thinking that it's not supercritical where they're placed, as long as the Ardunio can be attached with screws through a couple of the holes in the acrylic plate?
-- The acrylic plate has some kind of paper backing that doesn't seem to come off easily. Do most people leave it on? Does it make a big difference?
frank23
Re: Couple of basic setup questions re the ARDX kit
by franklin97355 on Sat Mar 04, 2017 12:14 am
Mine didn't fit all the holes either so I just used the ones I could and it was fine. The paper is to protect the plastic when working an machining it. You can leave it or not as it does not affect the boards at all.
franklin97355
by thosbryan on Mon Jan 08, 2018 7:52 am
The rubber feet will stick better to the plastic, not the paper.
thosbryan
