The Temperature/Sensor sensor calls to the following library
- Code: Select all | TOGGLE FULL SIZE
/* DHT library
MIT license
written by Adafruit Industries
#ifndef DHT_H
#define DHT_H
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
// Uncomment to enable printing out nice debug messages.
//#define DHT_DEBUG
// Define where debug output will be printed.
#define DEBUG_PRINTER Serial
// Setup debug printing macros.
#ifdef DHT_DEBUG
#define DEBUG_PRINT(...) { DEBUG_PRINTER.print(__VA_ARGS__); }
#define DEBUG_PRINTLN(...) { DEBUG_PRINTER.println(__VA_ARGS__); }
#else
#define DEBUG_PRINT(...) {}
#define DEBUG_PRINTLN(...) {}
#endif
// Define types of sensors.
#define DHT11 11
#define DHT22 22
#define DHT21 21
#define AM2301 21
class DHT {
public:
DHT(uint8_t pin, uint8_t type, uint8_t count=6);
void begin(void);
float readTemperature(bool S=false, bool force=false);
float convertCtoF(float);
float convertFtoC(float);
float computeHeatIndex(float temperature, float percentHumidity, bool isFahrenheit=true);
float readHumidity(bool force=false);
boolean read(bool force=false);
private:
uint8_t data[5];
uint8_t _pin, _type;
#ifdef __AVR
// Use direct GPIO access on an 8-bit AVR so keep track of the port and bitmask
// for the digital pin connected to the DHT. Other platforms will use digitalRead.
uint8_t _bit, _port;
#endif
uint32_t _lastreadtime, _maxcycles;
bool _lastresult;
uint32_t expectPulse(bool level);
class InterruptLock {
public:
InterruptLock() {
noInterrupts();
~InterruptLock() {
interrupts();
#endif
And the message section of the code that sends the data to the web interface is as follows
#include <Adafruit_Sensor.h>
#include <ArduinoJson.h>
#include <DHT.h>
#include <MQ2.h>
#include <hpma115S0.h>
#include <SoftwareSerial.h>
#if SIMULATED_DATA
hpma115S0.Init();
hpma115S0.StartParticleMeasurement();
void initSensor()
// use SIMULATED_DATA, no sensor need to be inited
float readTemperature()
return random(20, 30);
float readHumidity()
return random(30, 40);
#else
static DHT dht(DHT_PIN, DHT_TYPE);
static MQ2 mq2(MQ_PIN);
SoftwareSerial hpmaSerial(TX, RX);
void initSensor()
dht.begin();
hpmaSerial.begin();
int GetPM2_5()
return hpma115S0.GetPM2_5();
float readLPG()
return mq2.readLPG();
float readSmoke()
return mq2.readSmoke();
float readCO()
return mq2.readCO();
return dht.readTemperature();
return dht.readHumidity();
#endif
bool readMessage(int messageId, char *payload)
float smoke = readSmoke();
init _pm2_5 = GetPM2_5();
float lpg = readLPG();
float co = readCO();
float humidity = readHumidity();
float temperature = readTemperature();
StaticJsonBuffer<MESSAGE_MAX_LEN> jsonBuffer;
JsonObject &root = jsonBuffer.createObject();
root["deviceId"] = DEVICE_ID;
root["messageId"] = messageId;
bool temperatureAlert = false;
// NAN is not the valid json, change it to NULL
if (std::isnan(_pm2_5))
root["_pm2_5"] = NULL;
else
root["_pm2_5"] = _pm2_5;
if (std::isnan(smoke))
root["smoke"] = NULL;
else
root["smoke"] = smoke;
if (std::isnan(lpg))
root["lpg"] = NULL;
else
root["lpg"] = lpg;
if (std::isnan(co))
root["co"] = NULL;
else
root["co"] = co;
if (std::isnan(temperature))
root["temperature"] = NULL;
else
root["temperature"] = temperature;
if (std::isnan(humidity))
root["humidity"] = NULL;
else
root["humidity"] = humidity;
/* My modification */ root["tempAlert"] = temperatureAlert;
root.printTo(payload, MESSAGE_MAX_LEN);
return temperatureAlert;
void parseTwinMessage(char *message)
JsonObject &root = jsonBuffer.parseObject(message);
if (!root.success())
Serial.printf("Parse %s failed.\r\n", message);
return;
if (root["desired"]["interval"].success())
interval = root["desired"]["interval"];
else if (root.containsKey("interval"))
interval = root["interval"];
As you can see,
the call
pulls the senor data
the code
defines the value pulled
and the code
else
tells the program to send that data to the server via another rest part of the code
This is the basic functionality and it works great.
I've attached a different sensor and i'm having trouble figuring how to extract that code from it in a similar fashion because it doesn't come with any truadional library where i can easily translate it like I was able to with the DHT library
It is for the Honeywell HPMA115S0-XXX Particle Sensor
The code for simply reading the data from the unit and displaying it to a serial port is as follows
* Read particle matter using a Honeywell HPMA115S0-XXX and a ESP8266 (WeMos Mini)
#define DEBUG false
#define pin_rx D5
#define pin_tx D6
SoftwareSerial Device(pin_rx, pin_tx);
const int AutoSendOn[4] = {0x68, 0x01, 0x40, 0x57};
const int AutoSendOff[4] = {0x68, 0x01, 0x20, 0x77};
const int StartPmMeasure[4] = {0x68, 0x01, 0x01, 0x96};
const int StopPmMeasure[4] = {0x68, 0x01, 0x02, 0x95};
const int ReadPm[4] = {0x68, 0x01, 0x04, 0x93};
int isAutoSend = true;
int useReading = true;
int pm25 = 0; // PM2.5
int pm10 = 0; // PM10
unsigned long lastReading = 0;
void sendCommand(const int *cmd) {
int i;
for(i=0;i<4; i++) {
Device.write(cmd[i]);
// let a unicorn pass
delay(10);
int readResponse(int l = 32) {
int i = 0;
int buf[l];
unsigned long start = millis();
while(Device.available() > 0 && i < l) {
buf[i] = Device.read(); // read bytes from device
if(DEBUG) {
Serial.print("i: "); Serial.print(i);
Serial.print(" buf[i]: "); Serial.println(buf[i], HEX);
// check for HEAD or skip a byte
if(i == 0 && !(buf[0] == 0x40 || buf[0] == 0x42 || buf[0] == 0xA5 || buf[0] == 0x96)) {
if(DEBUG) { Serial.println("Skipping Byte"); }
continue;
} else {
i++;
if(buf[0] == 0x42 && buf[1] == 0x4d) { // Autosend
if(DEBUG) { Serial.println("Autosend"); }
l=32;
if(buf[0] == 0x40 && buf[2] == 0x4) { // Reading
if(DEBUG) { Serial.println("Reading"); }
l=8;
if(buf[0] == 0xA5 && buf[1] == 0xA5) { // Pos. ACK
if(DEBUG) { Serial.println("ACK"); }
return true;
if(buf[0] == 0x96 && buf[1] == 0x96) { // Neg. ACK
if(DEBUG) { Serial.println("NACK"); }
return false;
if (millis() - start > 1000) { // trigger Timeout after 1 sec
Serial.println("Timeout");
return false;
// check checksum in Reading
if(buf[2] == 0x04) {
// HEAD+LEN+CMD
int cs = buf[0] + buf[1] + buf[2];
int c;
// DATA
for(c = 3; c < (2 + buf[1]); c++) {
// Serial.println(buf[c]);
cs += buf[c];
// CS = MOD((65536-(HEAD+LEN+CMD+DATA)), 256)
cs = (65536 - cs) % 256;
// validate checksum
if(cs == buf[c]) {
// calculate PM values
pm25 = buf[3] * 256 + buf[4];
pm10 = buf[5] * 256 + buf[6];
return true;
} else {
Serial.println("Checksum mismatch");
} else if(buf[3] == 0x1c) { // Autoreading
int cs = 0;
int c;
// DATA
for(c = 0; c <= buf[3]; c++) {
cs += buf[c];
int checksum = buf[30] * 256 + buf[31];
if(DEBUG) {
Serial.print("Checksum: "); Serial.print(checksum, HEX);
Serial.print(" CS: "); Serial.println(cs, HEX);
if(cs == checksum) {
pm25 = buf[6] * 256 + buf[7];
pm10 = buf[8] * 256 + buf[9];
return true;
} else {
} else {
// unkown
return false;
// init Serial for ESP8266
Serial.begin(115200); Serial.println();
// init Serial for Device
Device.begin(9600); Device.println();
if(millis() - lastReading >= 1000 || lastReading == 0) {
lastReading = millis();
// handle AutoSend
if(isAutoSend) {
if(useReading) {
if(readResponse()) {
Serial.print("PM 2.5: "); Serial.print(pm25);
Serial.print(" / PM 10: "); Serial.println(pm10);
} else { // disable
Serial.println("Stop AutoSend");
sendCommand(AutoSendOff);
Serial.println("AutoSend disabled.");
isAutoSend = !isAutoSend;
} else {
sendCommand(ReadPm);
Can anyone please help me with a way to call off the data in a way similar to the DHT sensor so that I can simply pull the value and send it to the IOT cloud like I have the other sensors?
The full Azure Code is attached here https://github.com/rezivor/Multisensor
