Hallowing M0 tutorial does not work.
by DiSim on Wed Oct 28, 2020 1:09 pm
Today i got my Hallowing M0 and i started with the tutorial. Everything was fine until i came to this step: https://learn.adafruit.com/adafruit-hal ... est-sketch
I think i did everything like i should but if i try to compile it i got an error:
/Users/admin/Documents/Arduino/libraries/Adafruit_Arcada_Library/arcadatype.h:111:3: error: 'TSPoint' does not name a type; did you mean 'Point'?
111 | TSPoint getTouchscreenPoint(void);
| Point
What did i wrong????
Thank You for Your help
Dirk
DiSim
Re: Hallowing M0 tutorial does not work.
by dastels on Wed Oct 28, 2020 1:48 pm
Did you get all the libraries installed? https://learn.adafruit.com/adafruit-hallowing/arcada-libraries
A type being missing typically means a library hasn't been installed.
dastels
by adafruit_support_carter on Wed Oct 28, 2020 1:51 pm
Just did a test compile here and it worked OK.
Go back through and make sure you've installed all the needed libraries:
https://learn.adafruit.com/adafruit-hal ... -libraries
by DiSim on Wed Oct 28, 2020 1:52 pm
Ty for the fast response.
Yes i did, i checked it 3 times.
DiSim
by dastels on Wed Oct 28, 2020 2:00 pm
Are all libraries up to date? Are all board support packages up to date? Do you have the correct board selected?
dastels
by DiSim on Wed Oct 28, 2020 2:08 pm
I started today, so i installed everything today, i did always use the newest version. And if i check the Library Manager for updatable there is nothing.
I did upload other sketches and they worked, so the board settings should be ok.
DiSim
by dastels on Wed Oct 28, 2020 2:16 pm
Can you post the output from compiling, please.
dastels
by DiSim on Wed Oct 28, 2020 2:20 pm
This is the output:
In file included from /Users/admin/Documents/Arduino/libraries/Adafruit_Arcada_Library/Boards/Adafruit_Arcada_HalloWingM0.h:31,
from /Users/admin/Documents/Arduino/libraries/Adafruit_Arcada_Library/Adafruit_Arcada.h:22,
from /Users/admin/Documents/Arduino/libraries/Adafruit_Arcada_Library/examples/full_board_tests/hallowingm0_arcadatest/hallowingm0_arcadatest.ino:1:
| Point
Multiple libraries were found for "Adafruit_ZeroDMA.h"
Used: /Users/admin/Library/Arduino15/packages/adafruit/hardware/samd/1.6.3/libraries/Adafruit_ZeroDMA
Not used: /Users/admin/Documents/Arduino/libraries/Adafruit_Zero_DMA_Library
Multiple libraries were found for "TouchScreen.h"
Used: /Users/admin/Documents/Arduino/libraries/TouchScreen
Not used: /Users/admin/Documents/Arduino/libraries/Adafruit_TouchScreen
exit status 1
Error compiling for board Adafruit Hallowing M0.
DiSim
by adafruit_support_carter on Wed Oct 28, 2020 2:24 pm
Uninstall this library:
by DiSim on Wed Oct 28, 2020 2:32 pm
it works!!! :-)
Thank You very much for Your fast help.
DiSim
