PWM
PWM
by magician13134 on Thu Nov 01, 2007 9:52 pm
Ok... I'm a little confused about PWM.... in this example:
http://www.arduino.cc/en/Tutorial/Fading
Is the light actually dimming or does it just APPEAR to be because it's blinking so fast?
Why can I only do it on some pins?
Is this the same method in the code for dithered images/Knight Rider effect on the MiniPOV?
magician13134
by adafruit on Thu Nov 01, 2007 11:31 pm
1. it only appears to be
2. it uses special chip hardwar
3. probably not, see #2
by magician13134 on Fri Nov 02, 2007 6:34 am
So digital is just On or Off, but analog is... anything? Can you use the analog pins as outputs?
magician13134
by adafruit on Fri Nov 02, 2007 10:21 am
you probably want to post arduino questions to the arduino forum...i havent written a tutorial covering this material (yet)
