Modifing code in Lezzon 5
by ttownfire on Sat Nov 24, 2007 3:51 pm
Hello -
I'm messing around with the lezzon 5 and I'm modifing the code to add another "if" statement and function. Here is the code:
 *  Bike light, final version
int switchPin = 2;              // switch is connected to pin 2
int led1Pin = 12;
int led2Pin = 11;
int led3Pin = 10;
int led4Pin = 9;
int led5Pin = 8;
int val;                        // variable for reading the pin status
int val2;                       // variable for reading the delayed status
int buttonState;                // variable to hold the button state
int lightMode = 0;              // What mode is the light in?
  pinMode(switchPin, INPUT);    // Set the switch pin as input
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(led3Pin, OUTPUT);
  pinMode(led4Pin, OUTPUT);
  pinMode(led5Pin, OUTPUT);
  Serial.begin(9600);           // Set up serial communication at 9600bps
  buttonState = digitalRead(switchPin);   // read the initial state
void loop(){
  val = digitalRead(switchPin);      // read input value and store it in val
  delay(10);                         // 10 milliseconds is a good amount of time
  val2 = digitalRead(switchPin);     // read the input again to check for bounces
  if (val == val2) {                 // make sure we got 2 consistant readings!
    if (val != buttonState) {          // the button state has changed!
      if (val == LOW) {                // check if the button is pressed
        if (lightMode == 0) {          // if its off
          lightMode = 1;               // turn lights on!
        } else {
          if (lightMode == 1) {        // if its all-on
            lightMode = 2;             // make it blink!
          } else {
            if (lightMode == 2) {      // if its blinking
              lightMode = 3;           // make it wave!
            } else {
         if (lightMode == 3) { //  if its waving,
                 lightMode = 4;          // make it shrink
              } else {
                if (lightMode == 4) {  // if its shrinking
                  lightMode = 0;      // turn it off
    buttonState = val;                 // save the new state in our variable
  // Now do whatever the lightMode indicates
  if (lightMode == 0) { // all-off
    digitalWrite(led1Pin, LOW);
    digitalWrite(led2Pin, LOW);
    digitalWrite(led3Pin, LOW);
    digitalWrite(led4Pin, LOW);
    digitalWrite(led5Pin, LOW);
  if (lightMode == 1) { // all-on
    digitalWrite(led1Pin, HIGH);
    digitalWrite(led2Pin, HIGH);
    digitalWrite(led3Pin, HIGH);
    digitalWrite(led4Pin, HIGH);
    digitalWrite(led5Pin, HIGH);
  if (lightMode == 2) { // blinking
    delay(100);
    delay(100);
  if (lightMode == 3)  { // "wave"
    delay(50);
    delay(50);
    delay(50);
    delay(50);
    delay(50);
    delay(50);
    delay(50);
    delay(50);
    delay(50);
    delay(50);
    delay(50);
Its giving me and error: you can't put function before the "{" token. Will someone take a look and see what I've done wrong? Thank you!
ttownfire
Lesson 5 code
by timv on Sat Nov 24, 2007 4:33 pm
I'm sure you have a problem with your { and } not matching up. I'm not even going to try to figure out where. In short, that's a really awful way to write C code, among other things because it's insanely hard to tell if your { and } match up, or where the problem is if they don't.
Try this:
  void loop(){
        ++lightMode;
        if (lightMode > 4)
          lightMode = 0;
// etc...
timv
by adafruit on Wed Nov 28, 2007 1:59 am
s'kinda my fault, i should have posted better example code. :(
