is there a specific way you are sapposed to turn off, or shut off the arduino before you pull the usb cable out. Because i want to make sure that every time i am simply pulling out the chord i a not messing up the ardiuno. And is the code sapposed to stop, or is it saved until i overwrite the code with more code? is there a way to stop the code, and if so is the code sapposed to be still running when i pull out the usb cable?
thnks
-rfmaster
turning arduino off saftley
Re: turning arduino off saftley
nobig93 wrote:is there a specific way you are sapposed to turn off, or shut off the arduino before you pull the usb cable out.
if its not powered, its not runningAnd is the code sapposed to stop, or is it saved until i overwrite the code with more code?
sketches are stored in the arduino 'permanently'
yes, unplug the arduinois there a way to stop the code,
