Ok... I've got to be overlooking something simple. I'm just trying to get the .56" 7-segment with LEDbackup (Part# 879) to work with my Arduino Uno. I have followed the steps in the tutorial here: https://learn.adafruit.com/adafruit-led ... t-backpack
Libraries were downloaded and no errors received when uploading firmware. I have inserted print statements to make sure code is being executed.
I can not get the display to light up at all. Am I correct that no jumpers are necessary with just one display? I've heard to make sure I'm using a "Charge" USB cable instead of a "Data" USB cable. Would this be my problem if the Uno is functioning? How can you tell the differences in cables?
Thanks in advance for any assistance.
7 segment LED w/backpack
- Franklin97355
Re: 7 segment LED w/backpack
Could you post large (less than 1meg,), clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
- flyboy99
Here's the display soldered onto the backpack. Not sure if the detail is good enough to be helpful. Not very pretty but have checked for solder shorts. I don't have the plug to the header in the pic. I have verified that 5V is getting to the display and also checked continuity on the Clock and Data pins.
- IMAG0488[1].jpg (563.78 KiB) Viewed 887 times
- IMAG0489[1].jpg (543.55 KiB) Viewed 887 times
Please post some photos showing your connections to the Arduino.
What software are you using to communicate with the display?
- flyboy99
The software is the example sketch (i.e. File?Examples?Adafruit_LEDBackpack?sevenseg)
Firmware is running as I see the "7 Segment Backpack Test" print line when viewing the Serial Monitor. Let me know if the pictures show what you want to see.
- IMG_1862.JPG (44.38 KiB) Viewed 812 times
- IMG_1865.JPG (37.45 KiB) Viewed 812 times
- IMG_1864.JPG (43.62 KiB) Viewed 812 times
That all looks correct. Please contact [email protected] with a link to this thread and request a replacement kit.
- flyboy99
Thank you! I am very impressed with the quick response and handling of this post. This is first order with Adafruit but not my last... you truly do put the customer first!
