Arduino Lesson 3. help
by Glassy123 on Fri Apr 15, 2016 4:01 am
Hi all,
I'm having a weird issue with this lesson. I have everything connected as it should be, but when everything is connected I only get a pulse of green and light green, but with the ground unplugged I get a pulse of red/blue/purple. It looks like the green colour signal is not being sent with the ground in.
I'm using a seeeduino in combination with the standard parts, have tested with two different boards and same result.
Lesson is here: https://learn.adafruit.com/adafruit-ard ... leds/parts
A pic of the setup:
http://imgur.com/kSJHRgU (sorry the img linker dosnt seem to be working)
Any help would be greatly appreciated! Thank you!
Glassy123
Re: Arduino Lesson 3. help
by adafruit_support_bill on Fri Apr 15, 2016 6:22 am
Are you using a common cathode led or a common anode led?
by Glassy123 on Fri Apr 15, 2016 7:52 am
Ah looks like I have an anode, thought it was a cathode this whole time...silly me!
Finally got it to work once I changed the code around
Thank you!
Glassy123
