EEPROM library
EEPROM library
by w3asa on Fri May 27, 2016 10:01 pm
I recently purchased the Arduino uno starter kit and downloaded ver 1.7.9 of the IDE. I have a project where I want to store int and float data types in the EEPROM. .write() and .read() compile but .put() and .get() don't. Do i need a different version of the EEPROM library or is there a simple workaround using read/write?
w3asa
Re: EEPROM library
by franklin97355 on Fri May 27, 2016 10:53 pm
Do you mean 1.6.9? Which EEprom library are you using?
franklin97355
Re: EEPROM library
by w3asa on Sat May 28, 2016 8:01 am
No, its version 1.7.9 which I downloaded from arduino.org. I understand there is an arduino.cc which resulted from a split in the community. Should I use that instead?
w3asa
Re: EEPROM library
by franklin97355 on Sat May 28, 2016 11:19 am
Yes, Arduino.cc is the original and the group we do business with.
franklin97355
