Hi. I bought a powerboost 500 shield and a 2000mAh Li-ion battery. I plugged the battery and a USB charger in the shield, the charging light is lit, but the Done light never comes up. It's been plugged in for more than 24 hours, and it's still showing Charging. Does it mean that something is broken, or is it not going to show the correct status until the shield is actually connected to an Arduino? I didn't solder anything, just plugged in the battery and the charger, didn't try to connect it to Arduino. The charger is a no-name one which I use to charge my ipad, and the USB cable is from a USB battery pack which works fine.
Battery + PowerBoost Shield - battery never charges complete
- muntyan
Re: Battery + PowerBoost Shield - battery never charges comp
If you have a multimeter, measure the voltage between the positive and negative wires on the LiPo cell.
- muntyan
A full charge would be 4.2v. Possible issues could be: If the power supply or cable can charge an iPad, they should be OK for a 2000mAh cell. Other possible issues are the cell itself or a problem with the charger. If you leave them connected for another couple of hours, does the measured battery voltage change?
- muntyan
Let's try replacing the shield. Please contact [email protected] with a link to this thread.
- muntyan
Thank you, ordered a replacement. Will report back here when that comes.
- SATRONICX
Bonjour,
J'ai un chargeur DW9118 7.2V - 14.4 ? a l'achat il est été en 110 volts or il été branché sur un réseau de 220 volts, il est donc hors service. Ce que je cherche c'est de le rendre en 220 volts, et souhaite avoir le schéma électrique pour pouvoir le faire. Vos conseils me seront très précieux.
@SATRONICX - this forum is for Adafruit products and your question is off-topic. If you post in "General Project Help" someone my have an answer for you.Hello,
I have a DW9118 7.2V - 14.4 charger? Has the purchase it is been in 110 volts gold it was connected on a network of 220 volts, so it is out of service. What I am looking for is to make it in 220 volts, and wishes to have the circuit diagram to be able to do it. Your advice will be very valuable to me
- SATRONICX
merci pour la réponse, pouvez-vous me donner le lien pour "General Project Help" merci
- muntyan
I got the replacement shield and it works: it charged the battery, and Done light got lit instead of Charging. Also, on this board, whenever I plug in the battery, 5V light is lit. That didn't happen with the old board (see the picture above).
Good to hear that is working for you now. Thanks for the follow-up.
