Displaying random element from array on OLED
by mattmans on Wed Oct 11, 2017 1:00 pm
Hi guys
C isn't my strong subject and I'm struggling with something which I thought would be simple.
I have an array of strings and I want to display a random one on an OLED display each time my Pro Trinket is turned on. I have it working with a single string, but I can't work out how to grab a random one from my array. Can anyone help?
Here's my code
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
String messagesArray[] = { "test 1", "test 2", "test 3" };         #This is the array that I want to pick a random string from
char message[] = "This works";               #This works
int  x, minX;
  Serial.begin(9600);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3D);  // initialize with the I2C addr 0x3D (for the 128x64)
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setTextWrap(false);
  x    = display.width();
  minX = -12 * strlen(message); // 12 = 6 pixels/character * text size 2
  display.clearDisplay();
  display.setCursor(x, 20);
  display.print(message);
  display.display();
  if(--x < minX) x = display.width();
Thanks for your help.
Matt
mattmans
Re: Displaying random element from array on OLED
by adafruit_support_rick on Wed Oct 11, 2017 3:05 pm
Arduino has a random() function and a randomSeed( function. You can read about them here:
You don't want to use a String object for your messages. You can simply use a character array.
Get a random number between 0 and (n-1), where n is the number of messages. Use that to index your array of messages:
#include <SPI.h>
#include <Wire.h>
char* messagesArray[] = { "test 1", "test 2", "test 3" };         //This is the array that I want to pick a random string from
//Get the nuber of messages in the array
#define MSG_COUNT (sizeof(messagesArray)/sizeof(char*))
//char message[] = "This works";               //This works
int  x, minX;
int messageIndex = 0;
  Serial.begin(9600);
  randomSeed(analogRead(0));  // initialize the randow number generator. must use an unconnected analog input
  messageIndex = random(MSG_COUNT);  //get a random number between 0 and the nuber of messages in the array (exclusive)
  minX = -12 * strlen(messagesArray[messageIndex]); // 12 = 6 pixels/character * text size 2
  display.print(messagesArray[messageIndex]);
  display.display();
  delay(1000);
by mattmans on Thu Oct 12, 2017 3:38 am
Thanks so much Rick - that's really helpful. It makes sense now that I've seen it.
I moved the messageIndex = random(MSG_COUNT); line out of the loop and into the setup section because it was changing the message randomly as it was scrolling across - an interesting effect, but not quite what I wanted on this occasion :)
Thanks again for your help!
Matt
mattmans
by adafruit_support_rick on Thu Oct 12, 2017 8:18 am
You’re welcome!
