ADAFRUIT STEMMA SOIL SENSOR - I2C CAPACITIVE MOISTURE SENSOR
by weal on Wed Oct 14, 2020 3:18 pm
The given temperature from the sensor means soil temperature or air?
Reading ranging from about 200 (very dry) to 2000 (very wet)
-Why dry doesn't start from 0 & wet ends in 100?.
-If 2000 represents (very wet) ,in which (minimum )value can be recorded wet by the sensor?
-What's different between ADAFRUIT STEMMA SOIL SENSOR and (SHT-?? Mesh sensors) ?
weal
Re: ADAFRUIT STEMMA SOIL SENSOR - I2C CAPACITIVE MOISTURE SE
by adafruit_support_carter on Thu Oct 15, 2020 6:40 pm
It's the temperature of the little chip on the board. It will be close to ambient air temperature, but can be off due to effects like local heating, etc.
The STEMMA Soil Sensor is a custom capacitive based solution, using the seesaw firmware and a SAMD21 microprocessor.
The values are essentially the raw readings from the sensor and don't have any actual units. They are simply correlated to the soil moisture levels indicated.
by weal on Fri Oct 16, 2020 9:27 am
-Which is better "ADAFRUIT STEMMA SOIL SENSOR" or "SHT Mesh sensor" to measure the water in the soil?
The sensor gives me "capread"
-What does mean by "capread"? is it refers to "Humidity " ?
I want to use send data from "ADAFRUIT STEMMA SOIL SENSOR" to sigfox cloud but I need to write parser , I don't know how to write it, I would be grateful if you could help me?
weal
by franklin97355 on Fri Oct 16, 2020 11:49 am
Can you post the code you are running to give that error?
franklin97355
by weal on Fri Oct 16, 2020 12:17 pm
franklin97355 wrote:Can you post the code you are running to give that error?
Thank you for your support.
soilsensor_lcd.ino
(1.11 KiB) Downloaded 1 time
weal
by adafruit_support_carter on Fri Oct 16, 2020 12:24 pm
It's the raw capacitive reading:
  uint16_t capread = ss.touchRead(0);
https://adafruit.github.io/Adafruit_See ... 85f7b2450f
by weal on Sat Oct 17, 2020 2:40 pm
Capacitive reading is refer to Humidity ?
weal
by franklin97355 on Sat Oct 17, 2020 10:21 pm
Capacitive reading is refering to soil moisture not air humidity.
franklin97355
by weal on Sun Oct 18, 2020 1:03 pm
Try touching the body of the sensor to make the 'moisture' measurement go up. In soil, you'll see this range from about 300 to 500, but make sure to test it by placing in a pot of soil and looking at the serial console to get an idea of what the range is. Note that it does depend on how packed/loose the soil is!
I didn't understand that.
When I have touched the body of the sensor, I did not get that range from about 300 to 500,every time I get Moisture: 1015
weal
by weal on Mon Oct 19, 2020 6:28 pm
Is it possible to use Sht-10 sensor instead of I2C CAPACITIVE MOISTURE SENSOR ?
https://learn.adafruit.com/wireless-gar ... fi-modules
is there any conflict and affected by the other sensors if I used all my CAPACITIVE MOISTURE SENSOR for one plant or one flied?
weal
