newb question
newb question
by foti on Sat Feb 27, 2021 10:43 am
I have a PAM8302a and a MAX4466 that I'm trying to get going here. I'm a software person so please bear with me. After getting the boards I wired them to a USB charger but all I got was popping and distortion from the speaker - nothing that sounded like what was being spoken. Adjusting gain and volume did nothing.
So I thought maybe it was the power supply and wired each board to its own battery but now I get nothing at all. See attached, please explain what I'm doing wrong or if I need new parts.
foti
Re: newb question
by adafruit_support_bill on Sat Feb 27, 2021 2:01 pm
I don't see any ground connection between your mic and your amp. You need a common ground for a signal reference.
Re: newb question
by foti on Mon Mar 08, 2021 9:12 am
I connected a common ground with battery, which didn't work. I also tried using one of your Mini Lipo chargers which also didn't work. Tried turning potentiometers in all directions, still nothing. At least before when I tried the Lipo charger I got some poppoing noises, which I'm not getting now. Are these part defective or am I still doing something wrong?
foti
Re: newb question
by adafruit_support_bill on Mon Mar 08, 2021 9:52 am
Since you have a single-ended input, you should connect the Audio In - pin to GND.
If there is still no sound, disconnect the signal wire from the output of the mic and briefly touch it to the VIN pin. You should hear a popping noise. That will verify that the amp is functioning.
Re: newb question
by foti on Thu Mar 11, 2021 2:15 pm
I'm not sure I understand and don't want to randomly connect stuff up. Could you please highlight the attached diagram with Windows Paint or other editing app to draw the connections I need to make?
foti
Re: newb question
by adafruit_support_bill on Thu Mar 11, 2021 2:38 pm
To test that the amplifier is working, connect as in the first diagram. Briefly touch the end the the 'Audio In +' wire (yellow) to the 5v pin on your charger board. You should hear a popping noise from the speaker. That will verify that the amplifier is working.
The second diagram is how everything should be connected for use with the microphone. Note that 'Audio In -' should be connected to GND.
