sharp ir sensor connector cable length
by rmuttt on Mon Sep 13, 2021 1:32 pm
Is there a maximum cable length from the sharp ir sensor to an arduino?
rmuttt
Re: sharp ir sensor connector cable length
by mikeysklar on Tue Sep 14, 2021 4:40 pm
@rmutt,
Cable length should not be a significant factor for the Sharp IR sensor (#157). If you need several feet of length then keep voltage drop due to wire resistance in mind. You can easily test with shorter distances of cable should the data becoming erratic.
mikeysklar
by rmuttt on Wed Sep 15, 2021 4:26 pm
I'm planning an installation where the sensors may be 15-20 feet from the central sound generator (a tsunami wav) Will this be a problem? Is there a way to drive the line? Thanks for your help.
rmuttt
by mikeysklar on Thu Sep 16, 2021 11:08 am
Once you have measured the resistance of 20' of the wire you plan to use for the IR sensor you can plug that into Ohm's law and calculate the voltage drop. I suspect that it will be substantial leading to signal problems, but why not estimate the numbers first and decide if you need to come up with another plan.
mikeysklar
