RA8875 Bitmap from RAM
by thesassyindian on Thu Sep 16, 2021 5:00 pm
Hello folks,
Is it possible to load bitmaps into RAM on the ESP32 and display them on the 800x480px 7" LCD screen?
Loading bitmaps from flash and displaying them takes a long time ~5000ms for a 180x180px image.
Even after changing BUFFPIXEL to
#define BUFFPIXEL 40
(I prefer not using an SD card)
Adafruit_ImageReader throws an error for the RA8875:
error: no matching function for call to 'Adafruit_Image::draw(Adafruit_RA8875&, int16_t, int16_t)'
Any help is greatly appreciated!
thesassyindian
Re: RA8875 Bitmap from RAM
by mikeysklar on Fri Sep 17, 2021 2:08 pm
Are you usign the ra8875_bitmap_fast.ino example?
https://github.com/adafruit/Adafruit_RA ... p_fast.ino
The error you are seeing:
I've come across this when the libraries were mismatched. Is everything up to date with github current releases? Adafruit_GFX and Adafruit_RA8875 libraries?
mikeysklar
