Servo Shield and RC Transmitter via Arduino Uno
Re: Servo Shield and RC Transmitter via Arduino Uno
by headbyte on Thu Oct 21, 2021 10:05 pm
I have some "hardware" chops. I've been an electronic & computer tech for over 20 yrs. But my coding sucks. :/
headbyte
by adafruit_support_bill on Fri Oct 22, 2021 8:13 am
Nice looking tank!
So how do I get this code . . . To work with the Servo Shield?
First, you need to include the library and declare your shield. Since you altered the default address, you will need to specify that in the constructor.
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver servos = Adafruit_PWMServoDriver(0x41);
And you can declare some handy constants for use in the code:
#define SERVOMIN  150 // This is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  600 // This is the 'maximum' pulse length count (out of 4096)
You can eliminate your include of the Servo.h and your declarations of the Servo objects and the servo attach statements, since they are no longer needed.
In your setup, you will need to add the following lines to initialize the shield.
  servos.begin();
  servos.setOscillatorFrequency(27000000);
  servos.setPWMFreq(50);  // Analog servos run at ~50 Hz updates
And this code:
        servo1.write(map(ch4, -100, 100, 0, 180));
        servo2.write(map(ch3, -100, 100, 0, 180));
can be replaced by:
        servos.setPWM(0, 0, map(ch4, -100, 100, SERVOMIN , SERVOMAX));  // for servo connected to shield channel 0
        servos.setPWM(1, 0, map(ch3, -100, 100, SERVOMIN , SERVOMAX));  // for servo connected to shield channel 1
by headbyte on Sat Oct 23, 2021 9:42 am
Thank you so much for your reply! This is great! I truly appreciate it.
headbyte
