NeoTrellis INT line Bug Report
by LuLu100 on Sun Jul 03, 2022 7:19 am
Bug Report:
The NeoTrellis INT line occasionally getting stuck low issue.
Reproduce Case:
I created a very simple reproduce case that is documented below:
Setup (pictures attached):
- (1) ItsyBitsy M4
- (1) NeoTrellis Keypad
- (1) Adafruit example code: interrupt.ino from the Adafruit seesaw Library\examples\NeoTrellis\interrupt\interrupt.ino
(this Adafruit example code polls the neotrellis INT line (there are no interrupts being used on the M4...the file name interrupt.ino is a bit confusing)
(this reproduce case is 100% Adafruit example code)
Test:
- press a kypd button a few times with the loop() delay set to 2ms.
- press a kypd button a few times with the loop() delay set to 50ms.
Results:
1) when the delay() in loop() is 2 ms the INT line does Not get stuck low
2) when the delay() in loop() is 50 ms the INT line Does get stuck low occasionally (anything >= a 7 ms delay() will cause the INT line to occasionally get stuck low)
Conclusions:
1) the length of the delay() in loop() appears to adversely affect the neotrellis INT pin's behavior
2) any code in loop() that takes longer then 7 ms to run will cause this issue to appear
3) this seems like a bug in the neotrellis firmware (ATSAMD09D14A see saw firmware)
4) this is a very straight forward way to reproduce the issue for testing and debugging
Let me know what you make of this reproduce case,
Louie
p.s. i have 13 of these neotrellis boards.
p.s. there is a workaround...detect when the INT line is stuck low and call NeoTrellis.SWReset()
p.s. i think Adafruit is awesome. I am very happy Adafruit customer. Your sw libraries make building so easy.
LuLu100
Re: NeoTrellis INT line Bug Report
by mikeysklar on Sun Jul 03, 2022 6:31 pm
Nice bug report. Thank you for narrowing down the timing and the hard work.
Would you mind filing it with the Adafruit Seesaw github repo?
https://github.com/adafruit/Adafruit_Seesaw/issues
mikeysklar
by LuLu100 on Tue Jul 05, 2022 10:44 am
Hi Mike,
I created a github issue per your request:
https://github.com/adafruit/Adafruit_Seesaw/issues/76
Louie
LuLu100
by mikeysklar on Tue Jul 05, 2022 2:26 pm
Louie,
Thank you for all your work here. Good stuff.
mikeysklar
by adafruit2 on Wed Jul 06, 2022 9:04 am
we're aware o the bug but have not had the time to sit down and figure out whats up!
adafruit2
Site Admin
