Need helping choosing bluetooth module-nRF8001 OR...?
inadeem
Post by inadeem »
I started a project and was using a HC-06 bluetooth module. I am now trying to use an iOS app to communicate with bluetooth so I need to purchase an iOS compatible bluetooth module.
I need a bluetooth module that would allow me to use the following code in it as well (mainly the PWM stuff):
const int pwmPin = 11;
const int TurnLightPin = 13;
//int delay_time = 1000;
int ledState = LOW; // ledState used to set the LED
unsigned long previousMillis = 0;  // will store last time LED was updated
const long interval = 500;  // interval at which to blink (milliseconds)
int dutyCycle = 0;
  // put your setup code here, to run once:
//Change register values to adjust PWM frequency for PWM Pins 3 and 11: http://arduino-info.wikispaces.com/Arduino-PWM-Frequency
//TCCR2B = TCCR2B & B11111000 | B00000100;    // set timer 2 divisor to    64 for PWM frequency of   490.20 Hz (The DEFAULT)
//TCCR2B = TCCR2B & B11111000 | B00000101;    // set timer 2 divisor to   128 for PWM frequency of   245.10 Hz
TCCR2B = TCCR2B & B11111000 | B00000110;    // set timer 2 divisor to   256 for PWM frequency of   122.55 Hz
//TCCR2B = TCCR2B & B11111000 | B00000111;    // set timer 2 divisor to  1024 for PWM frequency of    30.64 Hz  pinMode(TurnLightPin, OUTPUT);
 pinMode(pwmPin, OUTPUT);
  Serial.begin(9600); // Default baudrate of bluetooth -- 9600 bits/second
  Serial.println("HC-06 Bluetooth connected!!!");
  Serial.flush();
// check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
  unsigned long currentMillis = millis();
  if ((unsigned long)(currentMillis - previousMillis >= interval)) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
    } else {
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(TurnLightPin, ledState);
 //PWM Stuff:
while(Serial.available()){
  dutyCycle = Serial.parseInt();
  int pwmValue = (dutyCycle * 2.55 );
  analogWrite(pwmPin, pwmValue);
  Serial.print("PWMValue:");
  Serial.println(pwmValue);
} // End of While loop for PWM
} // End of void Loop
I was thinking about the nRF8001 but I read that the Adafruit Bluefruit LE UART Friend - Bluetooth Low is a better option?
Do I get one with UART or SPI? I'm not sure. My main goal is to be able to replicate the above code using either bluetooth module.
Is there a place where I can see the library functions and how to code using the bluetooth module?
Also, does the bluefruit iOS app have an option to make a custom controller layout? and have buttons send specific commands to the Arduino? (ex: if I click a button, I want it to send "A", if I click another button, I want it to send "B" etc..)?
I would really appreciate some help. Thank You.
adafruit_support_mike
Re: Need helping choosing bluetooth module-nRF8001 OR...?
Go with one of the nRF51822-based boards.
The nRF8001 is an older chip that doesn't support many of the features that make BLE popular. We keep it mostly for legacy reasons. The nRF51822 is a newer chip, and that's where our development is focused.
This tutorial seems to match what you're trying to do:
https://learn.adafruit.com/bluetooth-neopixel-goggles/
