DS3231 RTC Code or Hardware Problem?
Nofourk
Post by Nofourk »
I purchased a DS3231 RTC last week. Something is not right.
Tried using with Arduino UNO and Arduino MEGA 2360 with the same results. Installed the fork of JeeLab's excellent RTC library RTClib and used the example sketch shown on the product page.
Using with the battery I bought at the same time. Battery checks 3.3v. I cleaned the battery and the battery holder on the clock chip.
Attempting to troubleshoot I added one line of code at the start of the main loop.
Every time I start the Arduino I get this result on serial monitor:
RTC lost power, lets set the time!
This is in the main loop
2165/165/165 (Friday) 165:165:85
since midnight 1/1/1970 = 1551397585s = 17955d
now + 7d + 30s: 2019/3/8 12:16:31
this repeats forever.
Now what is interesting is I get the same results running the code even if I pull the clock from the setup and use the bare Arduino board!
Can anyone suggest what might be going on?
Franklin97355
Re: DS3231 RTC Code or Hardware Problem?
Post by Franklin97355 »
Could you post large (less than 1meg), clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
Nofourk
Post by Nofourk »
I hope this helps. One photo shows Vin and Gnd solder pretty close but I detect no bridge and infinite resistance between the pins.
2017-01-01 20.50.10.jpg (704.84 KiB) Viewed 3281 times
2017-01-01 22.58.40.jpg (898.15 KiB) Viewed 3281 times
2017-01-01 23.07.06.jpg (448.64 KiB) Viewed 3281 times
Two more pix coming.
Nofourk
Post by Nofourk »
2017-01-01 23.07.38.jpg (644.31 KiB) Viewed 3281 times
2017-01-01 23.55.12.jpg (946.33 KiB) Viewed 3281 times
adafruit_support_rick
We see this exact problem now and then. It is always a problem with wiring or soldering. Your soldering looks good, but you may have a bad jumper wire. Please try some different jumpers, and try some different breadboard locations.
Franklin97355
Try running your power jumpers directly from the Arduino to the board.
hirad
Post by hirad »
i had the same promlem in DS1307
Serial monitor output 165/165
change cristal 32kH
solve my problem
