Hi guys,
I'm trying to understand how to use the max31855 thermocouple breakout board library. In the tutorial, it tells us to define the pins for data out, clock, and data in. But when I look inside the library, I see to include an SPI.h library. Is this bitbanged SPI, or do I actually need to use SPI pins to make the board work?
Thank you!
Max31855 Library
- adafruit_support_bill
Re: Max31855 Library
It is 'bit-banged' SPI. You can use any pins with it.
- project_zero
Hi Bill,
According to the library it works with either Hardware SPI or bitbanged software SPI. For my project it would be useful to use the ICSP pins, so I'm trying to use the Hardware SPI. This text is within the example code that comes with the library:
However, though it works with software spi, I haven't gotten it to work with Hardware. I've double checked my wiring several times.
GND --> GND
Vin --> 5V
DO --> MISO ICSP Pin
CS --> Pin 7
CLK --> CLK ICSP Pin
And here is my code. It is the example code in its entirety, simply commented/uncommented to use hardware instead of software. I also added thermocouple.begin() to make sure SPI was being started. I do not get the message "Something wrong with thermocouple". I simply get that the internal temp is 0, C=0, and F=32. Those values do not change.
I know my thermocouple, board, and Arduino are working properly because the setup works with software spi. Do you have any idea why it isn't with hardware?
// Default connection is using software SPI, but comment and uncomment one of
// the two examples below to switch between software SPI and hardware SPI:
GND --> GND
Vin --> 5V
CS --> Pin 7
This is an example for the Adafruit Thermocouple Sensor w/MAX31855K
Designed specifically to work with the Adafruit Thermocouple Sensor
----> https://www.adafruit.com/products/269
These displays use SPI to communicate, 3 pins are required to
interface
products from Adafruit!
#include <SPI.h>
#include "Adafruit_MAX31855.h"
// Example creating a thermocouple instance with software SPI on any three
// digital IO pins.
#define MAXDO 3
#define MAXCS 4
#define MAXCLK 5
// initialize the Thermocouple
//Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
// Example creating a thermocouple instance with hardware SPI
// on a given CS pin.
//#define MAXCS 10
Adafruit_MAX31855 thermocouple(7);
while (!Serial); // wait for Serial on Leonardo/Zero, etc
Serial.begin(9600);
thermocouple.begin();
Serial.println("MAX31855 test");
// wait for MAX chip to stabilize
delay(500);
// basic readout test, just print the current temp
Serial.print("Internal Temp = ");
Serial.println(thermocouple.readInternal());
double c = thermocouple.readCelsius();
if (isnan(c)) {
Serial.println("Something wrong with thermocouple!");
} else {
Serial.print("C = ");
Serial.println(c);
Serial.print("F = ");
Serial.println(thermocouple.readFarenheit());
delay(1000);
Hmmm Looks like hardware SPI support was added later. But the library code looks pretty straightforward. What processor are you using this with?
