according to the data on Metro Mini description, (https://www.adafruit.com/product/2590) there should be a hardware SPI port, hardware I2C port pins on a mini metro board. But I'm unable to figure out which pins these would be. Is the description page incorrect?
SPI port/ I2C port pins on a mini metro
Re: SPI port/ I2C port pins on a mini metro
The i2c and SPI pinouts on the Metro Mini are the same as an UNO or any other Atmega328-based processor.
SPI is on pins: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK).
i2c is on pins A4 (SDA) and A5 (SCL)
- Robzzz
Thank you for your quick help. Everything is working well.
- Marshall0
Hello, My Name is Marshall,
I am an electrical engineering student student building a project with a 5V
metro mini, a SparkFun 6 Degrees of Freedom Breakout - LSM6DS3, and a logic
converter. So far all attempts to communicate with the sensor over I2C have
failed with both the included library and standard I2C protocal with just the wire.h library. When I measured the voltage of the clock line before passing
through the logic converter with a digital Analogue Discovery board using a
base of 1 ms, the clock line is stuck at 1.8 to 1.9V. I ordered through the
amazon link
https://www.amazon.com/gp/product/B016R ... UTF8&psc=1.
I went ahead and ordered a replacement just the other day and it has the same problem.
Help me please,
Marshall.
amazon link
Help me please,
Marshall.
What kind of 'logic converter'? Not all can handle bidirectional i2c signals.... and a logic converter.
- Marshall0
I was using the SparkFun Logic Level Converter - Bi-Directional, but when removed, the voltage of the data and clock line hang around 3.5 to 4 V, so it works with the sensors, but is noisy, I am probably going to order a 3.3V zener diode, place it on the circuit or make a voltage divider.
You should use a level converter specifically designed for i2c: https://www.adafruit.com/product/757
- lisleman
this is good info I'm glad I found it but I would have found it quicker if you included it on the pin-out page of the tutorial about this board.SPI is on pins: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK).
Thanks for the feedback. I will forward it to the author of the guide.
- adafruit2
good idea! added :)
