DRV2605L weak with LRA LVM061530
j2chau
Post by j2chau »
Hi, I have a DRV2605L driving a Jinlong Machinery & Electronics, Inc. LVM061530 and the output seems a little weak. I was wondering if I am doing something wrong hooking it up directly to it? Also if I want to hook up two independently controlled LVM061530 LRA, I would assuming I need two DRV260...
adafruit_support_mike
Re: DRV2605L weak with LRA LVM061530
We haven't tested the DRV2605 with LRAs, so we can't make recommendations about which ones work with it.
The most likely problem would be a mismatch between the DRV2605's output current and the current required to run the LRA your'e using. You can use an H-bridge like the TB6612 as a power booster:
https://www.adafruit.com/product/2448
To control two LRAs independently, yes, you'd need two DRV2605s. If you're controlling them through the I2C interface, you'll also need something like the TCA9548 I2C multiplexer:
https://www.adafruit.com/product/2717
The DRV2605's I2C address is hardwired, and you can't have multiple devices on the same I2C bus with the same address. The TCA9548 lets you swap among eight separate buses.
j2chau
Post by j2chau »
So I have figured out how to get the haptics to feel stronger on LRA. Need to use the useLRA() command.
Makes sense..
Thanks for posting the follow-up!
j2chau
Post by j2chau »
There were no documentation on that method. I think Adafruit needs to update the documentation.
chapel_81
Post by chapel_81 »
j2chau wrote:So I have figured out how to get the haptics to feel stronger on LRA. Need to use the useLRA() command.
I'm unclear how to implement this, can you tell me where to put this exactly?
MCor10
Post by MCor10 »
So I'm using the void useLRA() for a teensy 3.6 in the basic example code(I just started working with Teensy so please don't mind the sloppy work). It works a lot better now. But I expected the effects to feel stronger. I wonder if it has anything to do with the resonance frequency for which the voltage has to be tuned too?
#include <Wire.h>
#include "Adafruit_DRV2605.h"
Adafruit_DRV2605 drv;
int pin_SDA = 18;
int pin_SCL = 19;
  Serial.begin(9600);
  Wire.setSDA(pin_SDA);
  Wire.setSCL(pin_SCL);
  Serial.println("DRV test");
  drv.begin();
  drv.useLRA();
  drv.selectLibrary(6);
  // I2C trigger by sending 'go' command
  // default, internal trigger when sending GO command
  drv.setMode(DRV2605_MODE_INTTRIG);
uint8_t effect = 1;
  Serial.print("Effect #"); Serial.println(effect);
  // set the effect to play
  drv.setWaveform(0, effect);  // play effect
  drv.setWaveform(1, 0);       // end waveform
  // play the effect!
  drv.go();
  // wait a bit
  delay(500);
  effect++;
  if (effect > 123) effect = 1;
Return to “Other Arduino products from Adafruit”
