I am using an FX sound board in UART mode. The Adafruit sound board library requires that the reset RST line be attached to one of the Arduino pins. I have noticed that when I attach a USB connector between my computer and the FX board to upload OGG files, the computer does not recognize the sound board if the RST line is attached to the Arduino board. I do not have power applied to the Arduino, however, there are lines going from my breadboard on which the FX is mounted to the V+ and GND lines of the Arduino.
When the RST line is disconnected from the Arduino the computer can see the sound board.
My concern is that I may need to change the audio files on the sound board after the installation is no longer in a test phase and would not want to have to unsolder the RST line every time I do this. Is there an alternative to putting a switch on the RST line to accomplish this? Would I also need a disconnect the V+ and GND lines?
In playing with the power and reset lines I have again clobbered the file structure on the FX board because the computer did not properly eject the FX memory. Not having easy access to a modern Windows machine, this is a major drag. Are there no alternatives for installing the FX images files with a Mac OS?
FX Sound Board Reset Pin
- adafruit2
Re: FX Sound Board Reset Pin
huh we have never connected the RST line to an arduino, can you try adding a stronger pullup on the RST pin to 3.3V? maybe go with 2.2K?
- Dfitterman
I wanted to use the RST pin to determine programmatically if a soundboard was connected to the Arduino. I got the idea from the Adafruit FX soundboard example sketch menucommands, on which the following code snippet is based.
Is there another way to do this that doesn't use the RST line?
// Connect to the RST pin on the Sound Board
#define SFX_RST 4
// we'll be using software serial
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
Adafruit_Soundboard sfx = Adafruit_Soundboard(&ss, NULL, SFX_RST);
Serial.begin(115200);
Serial.println("Adafruit Sound Board!");
// softwareserial at 9600 baud
ss.begin(9600);
// can also do Serial1.begin(9600)
if (sfx.reset()) {
FXBoardPresent = true;
} else {
FXBoardPresent = false;
- CGrover
In a previous project, because of a hardware conflict, I left the reset pin disconnected and ran some tests. The reset pin needs to be defined in the sketch but had no impact on functionality nor reliability when electrically disconnected. Here's the posting of the test and test script used: viewtopic.php?f=19&t=118746#p593079
Didn't try to check status, though.
- mpacion
Can I use the USB port of an amplifier to power the fx Soundboard ?
Thanks in advance,
Thanks in advance,
- adafruit2
as long as there's no data wires yes!
- mpacion
Thank you very much for the quick reply
