My friend and I are trying to create a GPS tracking system that, on command, will SMS the longitude and latitude of its location to the original sender.
The SMS component works completely fine. but when I try to use the GPS component of the FONA, it does not return a single value. I'm using an Arduino Mega 2560.
I've also tried looking at the FONAtest example and using the GPS component of that, but it also just returns nothing. I've done the 3G baud rate example too, in order to set that up, but no avail.
Is this just a hardware problem? I've done a lot of research and have found nothing that solved my problem.
Thanks for any advice/help in advance.
3G FONA GPS
