I am trying to use an 9-DOF FXOS8700/FXAS21002 and a Feather M0 to build a simple flight controller for a foam-board airplane.
I set up and calibrated the 9-DOF, but the response time from the sensor seems sluggish. The Feather M0 can loop at around 100Hz (including logging to and SDI file), but when I pitch the airplane, it sometimes takes forever (ie, over 0.5 seconds) for the updated pitch to become available.
I have tried capturing pitch feedback in SDI file, in the Serial Monitor, and by flashing the LED on pin 8 (in case the problem was latency in the logging, instead of the sensor). None of those approaches seem to work.
The hardware docs for FXOS8700/FXAS21002 each say that output data rates are configurable up to 800Hz, but I don't know what the default configuration is using the Adafruit libraries. I also have a BMP280 that I intend to use as an altimeter.
I could examine the sensor on a timed interrupt, but right now I am just reading them in-line in loop(). I was guessing that is OK because loop() executes 100 times per second, but maybe I don't quite understand the implications of reading the sensors?
The sketch looks like this:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Mahony.h>
#include <Madgwick.h>
#include <Adafruit_BMP280.h>
#include <Adafruit_FXAS21002C.h>
#include <Adafruit_FXOS8700.h>
#include <SPI.h>
#include <SD.h>
* Pin assignments for BMP280 temperature and pressure sensor
#define BMP_SCK 10
#define BMP_MISO 11
#define BMP_MOSI 12
#define BMP_CS 13
//#define LOG_MODE 1
//#define SERIAL_MODE 1
#define LED_MODE 1
// Create sensor instances.
Adafruit_FXAS21002C gyro = Adafruit_FXAS21002C(0x0021002C);
Adafruit_FXOS8700 accelmag = Adafruit_FXOS8700(0x8700A, 0x8700B);
Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
// Mag calibration values are calculated via ahrs_calibration.
// These values must be determined for each board/environment.
// Offsets applied to raw x/y/z mag values
* Initial calibration including all metal masses (battery, motor),
float mag_offsets[3] = { 11.39F, -2.08F, 154.79F };
// Soft iron error compensation matrix
float mag_softiron_matrix[3][3] = { { 0.990, 0.004, 0.004 },
{ 0.004, 0.990, 0.001 },
{ 0.004, 0.001, 1.020 } };
float mag_field_strength = 46.21F;
// Offsets applied to compensate for gyro zero-drift error for x/y/z
float gyro_zero_offsets[3] = { 0.0F, 0.0F, 0.0F };
//Mahony filter; //lightweight; use on slower systems
Madgwick filter;
* Data logging file
File datalog;
const int chipSelect = 4;
int count = 0;
unsigned long start;
int flicker;
String getFileName(int i) {
String s = "DATA";
s += i;
s += ".txt";
return s;
File getNextAvailableFileHandle() {
int i = 0;
Serial.println(getFileName(i));
while (SD.exists(getFileName(i))) {
i++;
return SD.open(getFileName(i), FILE_WRITE);
void setup()
// built in green LED
pinMode(8, OUTPUT);
for (int i = 0; i < 10; i++) {
digitalWrite(8, HIGH);
delay(200);
digitalWrite(8, LOW);
delay(200);
Serial.begin(115200);
#ifdef SERIAL_MODE
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
#endif
Serial.println(F("Sensor & datalogging test."));
// Initialize the sensors.
if(!gyro.begin())
/* There was a problem detecting the gyro ... check your connections */
Serial.println("Ooops, no gyro detected ... Check your wiring!");
while(1);
if(!accelmag.begin(ACCEL_RANGE_4G))
Serial.println("Ooops, no FXOS8700 detected ... Check your wiring!");
while(1);
// initialize BMP temperature & pressure sensor
if (!bmp.begin()) {
Serial.println("Could not find a valid BMP280 sensor, check wiring!");
while (true);
// Based on a Bluefruit M0 Feather ... rate should be adjuted for other MCUs
filter.begin(75);
#ifdef LOG_MODE
// initialize SD memory card
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while(true);
datalog = getNextAvailableFileHandle();
if (!datalog) {
Serial.println("Cannot write data file.");
while(true);
#endif
start = millis();
void loop(void)
count++;
#ifdef LOG_MODE
if (millis() > start + 60 * 1000) {
datalog.flush();
datalog.close();
Serial.print("Completed: ");
Serial.println(count);
while(true);
#endif
sensors_event_t gyro_event;
sensors_event_t accel_event;
sensors_event_t mag_event;
// Get new data samples
gyro.getEvent(&gyro_event);
accelmag.getEvent(&accel_event, &mag_event);
// Apply mag offset compensation (base values in uTesla)
float x = mag_event.magnetic.x - mag_offsets[0];
float y = mag_event.magnetic.y - mag_offsets[1];
float z = mag_event.magnetic.z - mag_offsets[2];
// Apply mag soft iron error compensation
float mx = x * mag_softiron_matrix[0][0] + y * mag_softiron_matrix[0][1] + z * mag_softiron_matrix[0][2];
float my = x * mag_softiron_matrix[1][0] + y * mag_softiron_matrix[1][1] + z * mag_softiron_matrix[1][2];
float mz = x * mag_softiron_matrix[2][0] + y * mag_softiron_matrix[2][1] + z * mag_softiron_matrix[2][2];
// Apply gyro zero-rate error compensation
float gx = gyro_event.gyro.x + gyro_zero_offsets[0];
float gy = gyro_event.gyro.y + gyro_zero_offsets[1];
float gz = gyro_event.gyro.z + gyro_zero_offsets[2];
// The filter library expects gyro data in degrees/s, but adafruit sensor
// uses rad/s so we need to convert them first (or adapt the filter lib
// where they are being converted)
gx *= 57.2958F;
gy *= 57.2958F;
gz *= 57.2958F;
// Update the filter
filter.update(gx, gy, gz,
accel_event.acceleration.x, accel_event.acceleration.y, accel_event.acceleration.z,
mx, my, mz);
// Print the orientation filter output
// Note: To avoid gimbal lock you should read quaternions not Euler
// angles, but Euler angles are used here since they are easier to
// understand looking at the raw values. See the ble fusion sketch for
// and example of working with quaternion data.
* WIKIPEDIA (2017-10-06)
* Unit quaternions, also known as versors, provide a convenient mathematical
* notation for representing orientations and rotations of objects in three
* dimensions. Compared to Euler angles they are simpler to compose and avoid
* the problem of gimbal lock. Compared to rotation matrices they are more
* compact, more numerically stable, and may be more efficient.
* Gimbal lock is the loss of one degree of freedom in a three-dimensional,
* three-gimbal mechanism that occurs when the axes of two of the three gimbals
* are driven into a parallel configuration, "locking" the system into rotation
* in a degenerate two-dimensional space. The word lock is misleading: no gimbal
* is restrained. All three gimbals can still rotate freely about their respective
* axes of suspension. Nevertheless, because of the parallel orientation of two
* of the gimbals' axes there is no gimbal available to accommodate rotation along
* one axis.
float roll = filter.getRoll();
float pitch = filter.getPitch();
float heading = filter.getYaw();
#ifdef LOG_MODE
if (count % 100 == 0) {
// make a string for assembling the data to log:
String dataString = "";
dataString += count;
dataString += ",";
dataString += micros();
dataString += ",";
dataString += bmp.readTemperature();
dataString += ",";
dataString += bmp.readAltitude(1013.25);
dataString += ",";
dataString += heading;
dataString += ",";
dataString += pitch;
dataString += ",";
dataString += roll;
if (datalog) {
datalog.println(dataString);
#endif
#ifdef SERIAL_MODE
if (count % 1000 == 0) {
dataString += ",";
dataString += ",";
dataString += roll;
Serial.println(dataString);
#endif
#ifdef LED_MODE
if (pitch > 30.0 || pitch < -30.0) {
} else {
if (flicker % 30 > 15) {
} else {
flicker++;
#endif
