Gesture_sensor APDS9960
by Christianfalkenbergandersen on Sat Nov 18, 2017 1:28 am
For the gesture sensor library example sketch:
The extracted version would not verify without errors without adding the following line of code :
#include <Wire.h>
I stuck it in above the line :
#include “Adafruit_Adafruit_APDS9960.h”
- without it the compiler gave an error that the Wire.h was called but missing.
With this addition everything works fine.
( maybe it is because I am using the older arduino IDE 1.6.4? ).
Anyway I thought others may find it useful to know this as well
-I was going to include a screenshot but did not seem to be able to do this from my iPhone but I think you should be able to figure it out from my above description.
Re: Gesture_sensor APDS9960
by tkinsman on Wed Dec 13, 2017 6:53 pm
I've seen this error message about "Wire.h" someplace else in the forums, but cannot remember where.
I seem to remember that there was something seemingly unrelated that fixed the problem.
I'm sorry I can't be more help, but my message would be to look for the error message and see who else has found a solution.
Don't give up.
tkinsman
by Christianfalkenbergandersen on Wed Dec 13, 2017 7:26 pm
Well the way I described it did fix the problem.
I just thought other people would be interested as well.
by tkinsman on Wed Dec 13, 2017 9:54 pm
Oh. I see. Thanks for the help understanding.
tkinsman
