VEML6070 and TCA9548A
by jsalloneword on Mon Nov 20, 2017 5:40 pm
I am using the TCA9548A in order to read 3 x VEML6070 sensors into one Arduino device. I am firstly , just trying to get two sensors into the device. owever, I don't seem to be able to instance a second VEML6070 sensor correctly. I am trying to follow the format of the code on the tutorial you provided.
https://learn.adafruit.com/adafruit-tca ... g-and-test
You wire two HMC5883 magnetometers and I am aiming to follow the same principle with two VEML6070 sensors.
#include <Wire.h>
#include "Adafruit_VEML6070.h"
#define TCAADDR 0x70
/* Assign a unique ID to this sensor at the same time */
//Adafruit_HMC5883_Unified mag1 = Adafruit_HMC5883_Unified(1);
//Adafruit_HMC5883_Unified mag2 = Adafruit_HMC5883_Unified(2);
Adafruit_VEML6070 uv1 = Adafruit_VEML6070(1);
Adafruit_VEML6070 uv2 = Adafruit_VEML6070(2);
void displaySensorDetails(Adafruit_VEML6070 *uv)
 // sensor_t sensor;
  uv.begin(VEML6070_1_T);  // pass in the integration time constant
  Serial.println("VEML6070 Test"); Serial.println("");
  delay(500);
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
  Wire.endTransmission();
void setup(void)
  Serial.begin(115200);
  // Serial.println("VEML6070 Test");
  //uv.begin(VEML6070_1_T);  // pass in the integration time constant
  //Serial.println("VEML6070 Test"); Serial.println("");
  /* Initialise the 1st sensor */
  tcaselect(2);
  if (!uv1.begin())
    /* There was a problem detecting the HMC5883 ... check your connections */
    Serial.println("Ooops, no VEML6070 detected ... Check your wiring!");
    while (1);
  /* Initialise the 2nd sensor */
  tcaselect(6);
  if (!uv2.begin())
    while (1);
  /* Display some basic information on this sensor */
  tcaselect(2);
  displaySensorDetails(&uv1);
  tcaselect(6);
  displaySensorDetails(&uv2);
void loop(void)
  /* Get a new sensor event */
  //sensors_event_t event;
  tcaselect(2);
  uv1.getEvent(&event);
  /* Display the results (magnetic vector values are in micro-Tesla (uT)) */
  Serial.print("Sensor #1 - ");
  Serial.print("UV: "); Serial.println(uv1.readUV(1));
  tcaselect(6);
  uv2.getEvent(&event);
  Serial.print("Sensor #2 - ");
  Serial.print("UV: "); Serial.println(uv2.readUV(2));
  delay(500);
I get this error "no matching function call to Adafruit_VEML6070 uv2 = Adafruit_VEML6070(int);
so I presume I am calling the second instance of the second sensor incorrectly and Adafruit_VEML6070 will not allow an integer to be parsed through in this way. Having looked at the VEML6070 library on github I'm unsure how to do this.
I have also tried
Adafruit_VEML6070 uv1 = Adafruit_VEML6070();
Adafruit_VEML6070 uv2 = Adafruit_VEML6070();
and in void setup()
  uv1.begin(VEML6070_1_T);  // pass in the integration time constant
  uv2.begin(VEML6070_1_T);  // pass in the integration time constant
but I still get an error regarding how I have instanced the second sensor. If anyone can point me towards documentation on this that would be great.
Thank you
jsalloneword
Re: VEML6070 and TCA9548A
by adafruit_support_bill on Mon Nov 20, 2017 6:28 pm
The constructor for the VEML6070 does not take an ID parameter. You can tell them apart by what channel you have selected on the multiplexer.
by jsalloneword on Tue Nov 21, 2017 10:37 am
Hello, thanks for your reply. I did attempt without the ID parameter but the code still won't compile.
 if (!uv2.begin())
This line bring up an error 'no matching function/call to VEML6070 .begin()
Am I amble to instance more than one VEML6070 with that library?
This is what i have stripped the code back to.
#include <Wire.h>
  if (i > 7) return;
  Wire.write(1 << i);
void setup(void)
  tcaselect(2);
  if (!uv1.begin())
    /* There was a problem detecting the VEML6070 ... check your connections */
    while (1);
  tcaselect(6);
  if (!uv2.begin())
    while (1);
void loop(void)
  tcaselect(2);
  /* Display the results  */
  tcaselect(6);
  delay(500);
jsalloneword
by adafruit_support_bill on Tue Nov 21, 2017 11:12 am
You need to pass the integration time to the begin() function as described in the guide:
https://learn.adafruit.com/adafruit-vem ... #load-demo
by jsalloneword on Tue Nov 21, 2017 12:24 pm
I am doing that already in the code above inside of void setup but it does not resolve the error.
jsalloneword
by adafruit_support_bill on Tue Nov 21, 2017 12:41 pm
But you are calling begin a second time for each sensor. And in the second call you are not providing the required integration time.
  if (!uv1.begin())
    while (1);
  tcaselect(6);
  if (!uv2.begin())
    while (1);
by jsalloneword on Tue Nov 21, 2017 1:21 pm
Sorry ! I see what you mean now yes.
I've actually just removed the if conditions as I can't parse uv.begin(VEML6070_1_T) as a boolean only as a function.
Thanks for your help.
Functioning code for anyone also in need.
#include <Wire.h>
  if (i > 7) return;
  Wire.write(1 << i);
void setup(void)
  tcaselect(2);
  tcaselect(0);
  // connection state
  boolean notConnected = true;
  while (notConnected) {
    notConnected = false;
void loop(void)
  tcaselect(2);
  Serial.print("UV: "); Serial.println(uv1.readUV());
  delay(1000);
  tcaselect(6);
  Serial.print("UV: "); Serial.println(uv2.readUV());
  delay(1000);
jsalloneword
by adafruit_support_bill on Tue Nov 21, 2017 1:23 pm
Good to hear you have it working. Thanks for the follow-up.
cron
