PWM Servo Library Challenges
ChrisNZ
Post by ChrisNZ »
Just switched out an Arduino 101 for a Nano and having trouble since then. Using an Adafruit 16-Channel Servo Driver to drive servos and the library to match. One of the library calls seems to be crashing the Arduino.
When the following function is called, the Nano stops responding or doing anything.
void thumbMove() { //interupt the program and move the thumb
 unsigned long interrupt_time = millis();
      if (thumbPos == 0 && interrupt_time - last_interrupt_time > 100) {  // then finger is unlocked so lock it
      Serial.println("Closing Thumb");
      pwm.setPWM(1, 0, 515);
      thumbPos = 1;
    }  else {
      // then thumb is closed so open it
       if (interrupt_time - last_interrupt_time > 100) {
      Serial.println("Opening Thumb");
      pwm.setPWM(1, 0, 300);
      thumbPos = 0;
    last_interrupt_time = interrupt_time;
Running exactly the same sketch on the Nano and Arduino 101, but it worked fine on the Arduino 101. Have switched the environment to reflect the new board. The lines causing the problem are "pwm.setPWM(1, 0, 515);" and "pwm.setPWM(1, 0, 300);" If I comment out those lines, then the function goes fine. pwm.setPWM works fine in the main loop so it appears to be something with using the pwm.setPWM inside a function?
It doesn't appear to be related to power draw as the same problem occurs with the servos disconnected.
Here's the full code. I know some steps could be compacted, but haven't got to the optimisation stage yet!
// setup PWN module
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN  150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  600 // this is the 'maximum' pulse length count (out of 4096)
// set servo number on PWN module
uint8_t servonum = 0;
// prep variables
int pos;
int pos2 = 0;
int lastpos = 0;
int posDifference = 0;
volatile int thumbPos = 0;
volatile int fingerLock = 0;
static unsigned long last_interrupt_time = 0;
//setup buttons
int thumbPin = 2; //3 switch-wrist
int maxPin = 5; // 3 switch-middle
int minPin = 6; //3 switch-finger
int fingerLockPin = 3; //single switch
volatile int thumbVal = 0;     // variable for reading the pin status
// volatile int maxVal = 10;
// volatile int minVal = 500;
volatile int lockVal = 0;
  // setup serial monitor
  Serial.begin(9600);
  //setup PWM
  pwm.begin();
  pwm.setPWMFreq(60);  // Analog servos run at ~60 Hz updates
  yield();
    //setup buttons
  pinMode(thumbPin, INPUT);    // declare pushbutton as input
  digitalWrite(thumbPin, HIGH);  // set pin to high
  pinMode(minPin, INPUT);    // declare pushbutton as input
  digitalWrite(minPin, HIGH);  // set pin to high
  pinMode(maxPin, INPUT);    // declare pushbutton as input
  digitalWrite(maxPin, HIGH);  // set pin to high
  pinMode(fingerLockPin, INPUT);    // declare pushbutton as input
  digitalWrite(fingerLockPin, HIGH);  // set pin to high
  // setup button interupts
  attachInterrupt(digitalPinToInterrupt(thumbPin), thumbMove, LOW);
  attachInterrupt(digitalPinToInterrupt(minPin), resetMin, LOW);
  attachInterrupt(digitalPinToInterrupt(maxPin), resetMax, LOW);
  attachInterrupt(digitalPinToInterrupt(fingerLockPin), lockFinger, LOW);
  //servo scaling and clipping
  pos = getSensorAverageValue(0, 10, 5);
  Serial.println(pos);
  if (pos > 500) pos = 500;
  //decide if the change is big enough to justify a move
  posDifference = pos - lastpos;
  if (posDifference >=5 || posDifference <=-5) {
  //print state
 // Serial.println(pos);
  // work out change in state
  lastpos = pos;
  pos2 = map(pos, 25, 150, 0, 180);
  pos2 = constrain(pos2, 0, 180);
  // map - variable, original min, original max, new min, new max
  uint16_t pulselen = map(pos2, 1, 150, SERVOMIN, SERVOMAX);
  if (fingerLock == 0){
    // finger is unlocked so set position
  // set servo position
   pwm.setPWM(servonum, 0, pulselen);
  } else {
    //finger is locked so reset it?
    pwm.setPWM(servonum, 0, 0);
// get an average value from a jumpy or erratic input sensor.
const int getSensorAverageValue (const int sensorPin,
                                 const int numberOfSamples,
                                 const long timeGap)
  static int currentSample; // current sensor sample.
  static int currentValue;  // current sensor value.
  // current value works as a sum counter.
  currentValue = 0;
  // get sensor samples with delay and calculate the sum.
  for (int i = 0; i < numberOfSamples; i++) {
    // get sensor sample.
    currentSample = analogRead(sensorPin);
    // add sample to the sum counter.
    currentValue += currentSample;
    // delay some time for the next sample.
    delay(timeGap);
  // get the average sensor value (ignore the fraction).
  return (currentValue / numberOfSamples);
      //pwm.setPWM(1, 0, 515);
      thumbPos = 1;
    }  else {
      //pwm.setPWM(1, 0, 300);
      thumbPos = 0;
void resetMin() { //interupt the program and set the Min
    Serial.println("Minimum set");
      // to be added
void resetMax() { //interupt the program and set the Max
    Serial.println("Max set - updated");
      // to be added
Re: PWM Servo Library Challenges
On the Nano, interrupts are disabled on entry to an ISR. And, since i2c requires interrupts, any i2c calls made within the ISR will hang.
It is possible to re-enable interrupts in the ISR - but that is generally not considered good practice. https://www.arduino.cc/reference/en/lan ... nterrupts/
