Powering Adafruit 16-Channel 12-bit PWM/Servo Shield with 5v
by breenbeen on Fri Aug 10, 2018 6:32 pm
Hi there,
I currently have an Adafruit 16-Channel 12-bit PWM/Servo Shield - I2C interface hooked up to my Arduino UNO. The exact shield can be seen here:
https://www.adafruit.com/product/1411
To power the servos. I'm using a 6A, 5V power supply to do this. The exact power supply can be seen here:
https://ie.rs-online.com/web/p/embedded ... /?sra=pmpn
Now, the power supply is lighting up when connected to the wall fine however when I connect it to the connector on the servo shield it stops working and the light to show the V+ servo power on the shield is not on. I am definitely going to the right slots on each piece of hardware but it is not working. I am using standard copper plug wires to do the connection. Could that be the problem? I have ran the i2c_scanner sketch and I am communicating with the shield. I have a feeling I'm doing something wrong.
Could it be my wires? I'm going from V+ on the power supply to V+ on the shield and then the other outlet on the shiled goes to V- on the supply.
Any help on the matter would be hugely appreciated.
Thank you.
breenbeen
Re: Powering Adafruit 16-Channel 12-bit PWM/Servo Shield wit
by franklin97355 on Sat Aug 11, 2018 1:27 am
Can you post pictures of the shield and the soldering you've done?
franklin97355
cron
