How to get temperature data?
TZK
Post by TZK »
I baught two TMP007 (ID2023) sensors through Kyohritsu Electronic Industry Co., Ltd on August 2018.
When I ran the demo code "tmp007" downloding from the website (https://github.com/adafruit/Adafruit_TMP007_Library) using Arduino UNO, both of the sensors returned lines as below.
"Adafruit TMP007 example"
"No sensor found"
But today, one of the sensors returned lines;
"test".
In both cases, I cannot obtain any temperature data.
I have already checked that
-resistance between sensor board and UNO is less than 2 ohm for each of wires of VCC, GND, SDA and SCL,
-voltage between VCC and GND is 5V on sensor board,
-the demo code was succesfully written to the board.
Attached are photos of sensor board and end of the each wire.
sensor board 1
sensor board 1
sensor board 2
sensor board 2
The sensor gets hot when UNO board connects to PC.
Could you tell me how to check and solve our problem?
Return to “Other Arduino products from Adafruit”
