Rotary Encoder + Extras (Arduino)
- Lenigan96
I need some help regarding the use of this Rotary Encoder (https://www.adafruit.com/product/377). I want to use this with an Arduino project. I see this Rotary Encoder has five pins. I know the purpose of 3 of them (A,B and C). I would like to know the purpose of the other 2. I’m assuming that one of them is to connect the 5V pin of the Arduino and the other maybe controls the push-button.
- adafruit_support_bill
Re: Rotary Encoder + Extras (Arduino)
The other 2 pins are for the switch. The encoder and switch are passive devices. No 5v power is required.
- Lenigan96
I'm new to this so sorry if I make a dumb question haha. The "switch" is the push-button? Where do I connect the 2 remaining pins on my Arduino? Thanks for the help!
You would connect those two pins like any other SPST pushbutton switch: https://learn.adafruit.com/adafruit-ard ... duino-code
- Lenigan96
Thanks! Now I'm having trouble programming the rotary encoder to work with mi Arduino UNO. I’m using this code as reference
* Arduino Rotary Encoder Tutorial
* by Dejan Nedelkovski, www.HowToMechatronics.com
#define outputA 6
#define outputB 5
int counter = 0;
int aState;
int aLastState;
pinMode (outputA,INPUT);
pinMode (outputB,INPUT);
Serial.begin (9600);
// Reads the initial state of the outputA
aLastState = digitalRead(outputA);
aState = digitalRead(outputA); // Reads the "current" state of the outputA
// If the previous and the current state of the outputA are different, that means a Pulse has occured
if (aState != aLastState){
// If the outputB state is different to the outputA state, that means the encoder is rotating clockwise
if (digitalRead(outputB) != aState) {
counter ++;
} else {
counter --;
Serial.print("Position: ");
Serial.println(counter);
aLastState = aState; // Updates the previous state of the outputA with the current state
I've never seen it done that way. But that code might work if you turn the knob very slowly. It has several things working against it:
1) it is polling the pins.
2) it has two Serial.print statements in the polling loop.
3) At best it is giving you half of the resolution the encoder is capable of.
At 9600 baud, the serial prints will take about 15 milliseconds to execute. That means your poll rate is only about about 66Hz, so you will probably be missing some pulses.
Speeding up your baud-rate will help some.
But the best way to handle rotary encoders is with interrupts. The PJRC Encoder Library is an excellent implementation of interrupt driven encoder reading.
https://www.pjrc.com/teensy/td_libs_Encoder.html
- Lenigan96
Thanks a lot for the help! I’ll try to make my own code and see what happens haha
