I purchased the mini thermal printer kit.
The printer does not produce the test print at all. I used the included power supply, and when that did not work, I switched to a variable power supply and tried every voltage between 5-9. Only at 9 volts did the printer produce anything, but it was just "CP437" over and over. I have read on this forum that this means that there may be a short in my printer.
I am sure my paper is inserted correctly and that my power supply is reliable. I fear my printer may just be broken.
If there is anything I can do to make it work, please let me know.
Mini Thermal Printer Not Working
- gjeannet
Re: Mini Thermal Printer Not Working
update: i tried it again and now it prints cp437 at every voltage, not just 9v
- adafruit_support_carter
You've gone back to the 5V 2A supply that came with the kit and it still prints that when trying the self test?
