Fingerprint scanner - Perform Action for incorrect scan
thestand
Post by thestand »
Hello everyone,
I am currently working on a project that will implement the Adafruit fingerprint scanner (PRODUCT ID: 751). I have written code which when no fingerprint is scanned, the LCD writes "Enter a Fingerprint", and when a correct fingering is identified, the LCD writes "Success. Hello Tyler". This part works completely fine. I am having trouble with having the LCD write something when an incorrect scan occurs.
I have the full code below, but I will explain the modifications I have made to the example code provided by Adafruit. In the loop section, I have states, where no fingerprint is scanned, where a correct fingerprint is scanned, and where an incorrect fingerprint is scanned. This is noted by a variable called "attempt" equaling 0, 1, or 2, respectively. The default if for attempt to equal zero, but when a correct scan occurs, I set attempt equal to one, then run the LCD code, then set attempt back to zero.
My question is, where should I set attempt equal to 2? I have tried several places, but none have worked.
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  products from Adafruit!
  BSD license, all text above must be included in any redistribution
// include the library code:
#include <Wire.h>
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
#include <Adafruit_Fingerprint.h>
// On Leonardo/Micro or others with hardware serial, use those! #0 is green wire, #1 is white
// uncomment this line:
// #define mySerial Serial1
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// comment these two lines if using hardware serial
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
int attempt;
int p;
void setup()
  Serial.begin(9600);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit finger detect test");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
  } else {
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  finger.getTemplateCount();
  Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
  Serial.println("Waiting for valid finger...");
   // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  attempt = 0;
void loop()                     // run over and over again
  getFingerprintIDez();
  delay(50);            //don't ned to run this at full speed.
  if (attempt == 0) {   //user has not entered fingerprint
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("Enter a");
    lcd.setCursor(0, 1);
    lcd.print("Fingerprint");
  else if (attempt == 1){  //user has entered a correct fingerprint
    if (finger.fingerID == 1) {
      lcd.clear();
      lcd.print("Success");
      lcd.print("Hello Tyler");
      delay(1500);
      attempt = 0;
    if (finger.fingerID == 2) {
      lcd.clear();
      lcd.print("Hello Kaleb");
      delay(1500);
      attempt = 0;
  else if (attempt == 2) { //user has entered an incorrect fingerprint
    lcd.clear();
    lcd.print("Failure");
    lcd.print("Try Again");
    delay(1500);
    attempt = 0;
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.print("Image taken");
      break;
    case FINGERPRINT_NOFINGER:
      Serial.print("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.print("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.print("Imaging error");
      return p;
    default:
      Serial.print("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.print("Image converted");
      break;
    case FINGERPRINT_IMAGEMESS:
      Serial.print("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.print("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerFastSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    Serial.println("Communication error");
    attempt = 2;
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    attempt = 2;
    return p;
  } else {
    Serial.println("Unknown error");
    attempt = 2;
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
  return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK){
    return -1;
  if (p != FINGERPRINT_OK) {
    return -1;
    return -1;
  // found a match!
  // enter code here which you would like to execute when a patch is found
  attempt = 1;
-Tyler
Return to “Other Arduino products from Adafruit”
