1.2" Green 7 segment display flicker
by Cipriana on Mon Aug 12, 2019 2:24 pm
Having some flickering issues on the 1.2" 7 segment LED display. I have it hooked up to the I2C backpack but it is flickering a lot. The display is also a lot dimmer than I expected. Is this a connection problem or a soldering problem?
Cipriana
Re: 1.2" Green 7 segment display flicker
by adafruit_support_carter on Mon Aug 12, 2019 2:27 pm
Sounds like a power problem. How are you powering the display?
by Cipriana on Mon Aug 12, 2019 2:31 pm
I am using an ArduinoMega2560 to power it with 5V.
Cipriana
by adafruit_support_carter on Mon Aug 12, 2019 2:34 pm
That should be good. Let's check soldering. Can you post a photo showing the solder job on the backpack.
by Cipriana on Mon Aug 12, 2019 2:53 pm
Hope the quality is ok. I had to crop to fit the file limit.
one side.jpg (417.62 KiB) Viewed 209 times
other side.jpg (276.26 KiB) Viewed 209 times
Cipriana
by adafruit_support_carter on Mon Aug 12, 2019 4:10 pm
Thanks. It might be worth trying to reflow your solder connections. A few of them look under soldered with possibly insufficient wetting out.
https://learn.adafruit.com/adafruit-gui ... n-problems
These are just some that stand out, but check them all:
by Cipriana on Mon Aug 12, 2019 5:48 pm
I resoldered the pins and the flickering problem persists. Is there anything else I can try?
Cipriana
by adafruit_support_carter on Mon Aug 12, 2019 5:49 pm
Let's check software. Post full code for the sketch you are running.
by Cipriana on Mon Aug 12, 2019 5:53 pm
I am just running the sevenseg example code given from the adafruit github library. I did modify it a bit with matrix.setBrightness(255); , but that is the only change to the code.
Cipriana
by adafruit_support_carter on Mon Aug 12, 2019 6:26 pm
Try this and see if you still get the flickering:
#include "Adafruit_LEDBackpack.h"
Adafruit_7segment matrix = Adafruit_7segment();
  matrix.begin(0x70);
  matrix.print(8888, DEC);
  matrix.writeDisplay();
by Cipriana on Mon Aug 12, 2019 6:43 pm
Hmm...nothing happens when I run that code. I can see a faint greeness, but nothing else.
Cipriana
by adafruit_support_carter on Mon Aug 12, 2019 7:17 pm
OK, back to hardware. Can you post a photo of your setup showing how everything is wired together.
by Cipriana on Mon Aug 12, 2019 7:42 pm
Here is my setup. Hope there's a clue to the problem here...
Cipriana
by adafruit_support_carter on Mon Aug 12, 2019 8:40 pm
Thanks. Photos always help.
Your breadboard has split power rails. They are not continuous down the entire length of the breadboard. So the display is not being grounded. Jumper the rails or move the wire.
by Cipriana on Mon Aug 12, 2019 8:52 pm
It works!! Thank you so much for all the help!
Cipriana
