CAP1188 Sensor slow to respond
by Jimbee on Tue Aug 20, 2019 11:00 am
I have been playing with your cap1188 board and everything is working fine. The one issue I am seeing is when the sensor sits idle (no touches) it seems to be either timing out or going into a sleep/powerdown mode and takes a long time to respond when a touch is attempted. The led flashes every time but no activity via the I2C displaying on the Arduino IDE serial monitor. Any thoughts on this would be greatly appreciated.
Setup:
- Metro M4 using I2C interface to sensor.
- CAP1188 sensor board.
- Using the example code from your library.
Jimbee
Re: CAP1188 Sensor slow to respond
by adafruit_support_carter on Tue Aug 20, 2019 5:14 pm
How long do you have to wait without touching? How long is the delay in response once you do touch?
by Jimbee on Tue Aug 20, 2019 7:28 pm
Hi Carter,
Thanks for your reply. Testing so far It seems that delays of ~20 - 30 minutes between touches. The touch delay in response is ~10 - 15 seconds to respond and display on the IDE serial monitor. Once it seems to wake up, the touches are back to being very quick to respond.
Jimbee
by adafruit_support_carter on Wed Aug 21, 2019 11:48 am
It sounds like you are just testing this on a breadboard setup? Can you post a photo of your setup in case it might be related to that.
by Jimbee on Thu Aug 22, 2019 3:07 pm
Hi Carter,
Here is a photo of my setup. I am using an old red PCB ground plane as a touch pad.
Jimbee
by adafruit_support_carter on Thu Aug 22, 2019 3:19 pm
How is the CAP1188 being powered? I only see GND lines going from the Metro.
[EDIT]
Thought this sounded familiar.
viewtopic.php?f=25&t=155380
For troubleshooting, please try powering from the Metro using the wiring shown in the guide:
https://learn.adafruit.com/adafruit-cap ... out/wiring
and only connect one item at a time. In this case, the CAP1188.
by Jimbee on Fri Aug 23, 2019 11:13 am
Thanks for your reply. The cap board is being powered by a bench power supply 3.3Vdc. The metro is powered by USB.
I have tried powering the sensor from the metro - no change.
I have tried only one sensor on the I2C bus - no change.
It seems communication with the I2C or the IDE serial monitor goes away. The reason I say this is the cap sensor board LED always flashes with a touch so the sensing input circuit is alive.
Jimbee
by Jimbee on Fri Aug 30, 2019 11:20 am
Hi Carter,
I have decided to go in a different direction. Thanks for your help.
Jimbee
by adafruit_support_carter on Tue Sep 03, 2019 12:57 pm
OK, good luck. Not sure what was causing the original issue. We couldn't recreate it here.
