PyPortal and NeoPixels
by oldblackcrow on Sun Apr 18, 2021 5:14 pm
Hello all! I purchased NeoPixel LED Strip with 3-pin JST PH Connector - 60 LED/meter / 0.5 Meter and connected them to my PyPortal Pynt.
I only need 3 neopixels from the strip, so I cut after the 3rd neopixel.
After I ran the various version of the below code, I connected my power supply to only the hot and ground of the neopixels and the first neopixel lit up white.
I know the 3pin JST ports are marked incorrectly and have tried changing the following:
1. added PyPortal library references
2. changed the pixel pin to "pixel_pin = board.D3" and I tried "pixel_pin = board.D4"
Also tried "d3" and d4"
3. Then I tried commenting out the "pixels.fill((0, 255, 0))" and uncommenting the "pixels.fill((0, 255, 0, 0))" on all three sections.
4. Changed "RDER= RGB" to "RDER = neopixel.RGBW" and "RDER = neopixel.GRBW"
The lights do not come on at all.
I am at a loss. Thank you for your help!
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
import neopixel
from adafruit_pyportal import PyPortal
# On CircuitPlayground Express, and boards with built in status NeoPixel -> board.NEOPIXEL
# Otherwise choose an open pin connected to the Data In of the NeoPixel strip, i.e. board.D1
pixel_pin = board.NEOPIXEL
# On a Raspberry pi, use this instead, not all pins are supported
# The number of NeoPixels
num_pixels = 3
# The order of the pixel colors - RGB or GRB. Some NeoPixels have red and green reversed!
# For RGBW NeoPixels, simply change the ORDER to RGBW or GRBW.
ORDER = neopixel.GRBW
pixels = neopixel.NeoPixel(
    pixel_pin, num_pixels, brightness=0.2, auto_write=False, pixel_order=ORDER
def wheel(pos):
    # Input a value 0 to 255 to get a color value.
    # The colours are a transition r - g - b - back to r.
    if pos < 0 or pos > 255:
        r = g = b = 0
    elif pos < 85:
        r = int(pos * 3)
        g = int(255 - pos * 3)
        b = 0
    elif pos < 170:
        pos -= 85
        r = int(255 - pos * 3)
        g = 0
        b = int(pos * 3)
    else:
        pos -= 170
        r = 0
        g = int(pos * 3)
        b = int(255 - pos * 3)
    return (r, g, b) if ORDER in (neopixel.RGB, neopixel.GRB) else (r, g, b, 0)
def rainbow_cycle(wait):
    for j in range(255):
        for i in range(num_pixels):
            pixel_index = (i * 256 // num_pixels) + j
            pixels[i] = wheel(pixel_index & 255)
        pixels.show()
        time.sleep(wait)
while True:
    # Comment this line out if you have RGBW/GRBW NeoPixels
    #pixels.fill((255, 0, 0))
    # Uncomment this line if you have RGBW/GRBW NeoPixels
    pixels.fill((255, 0, 0, 0))
    pixels.show()
    time.sleep(1)
    #pixels.fill((0, 255, 0))
    pixels.show()
    time.sleep(1)
    #pixels.fill((0, 0, 255))
    pixels.fill((0, 0, 255, 0))
    pixels.show()
    time.sleep(1)
    rainbow_cycle(0.001)  # rainbow cycle with 1ms delay per step
oldblackcrow
Re: PyPortal and NeoPixels
by dastels on Sun Apr 18, 2021 10:32 pm
Do you, in fact, have RGBW pixls (as opposed to RGB)?
dastels
by oldblackcrow on Mon Apr 19, 2021 7:23 am
They are not, but I did try the RGB first and only attempted the WRGBs and the variants as a last ditch effort to get them to work.
oldblackcrow
by dastels on Mon Apr 19, 2021 8:31 am
"W" order variants are just for NeoPixels with a white element. The datastream is different, with each picxel taking 32 bits rather than 24. Even so you should see *somewhing* regardless of the order setting. If the oder doesn't match the pixels you just won't get the right colors.
Can you post a clear photo of your wiring?
dastels
by oldblackcrow on Mon Apr 19, 2021 4:17 pm
Thanks Dave!
Here are the images.
oldblackcrow
by oldblackcrow on Mon Apr 19, 2021 4:39 pm
I'm wondering now... I changed the I2C voltage to 3v and noticed that the neopixels are 5v... don't know if that affects this or not. However, When I tested on my power supply, I had it set on 3v and one neopixel lit up, so you're right, I should get something.
Here is the current code I'm running just to make sure I'm not messing that up.
import time
import board
import neopixel
num_pixels = 3
ORDER = neopixel.RGB
    pixel_pin, num_pixels, brightness=1.0, auto_write=True, pixel_order=ORDER
def wheel(pos):
        r = g = b = 0
    elif pos < 85:
        r = int(pos * 3)
        b = 0
    elif pos < 170:
        pos -= 85
        g = 0
        b = int(pos * 3)
    else:
        pos -= 170
        r = 0
        g = int(pos * 3)
        pixels.show()
        time.sleep(wait)
while True:
    # pixels.fill((255, 0, 0, 0))
    pixels.show()
    time.sleep(1)
    # pixels.fill((0, 255, 0, 0))
    pixels.show()
    time.sleep(1)
    # pixels.fill((0, 0, 255, 0))
    pixels.show()
    time.sleep(1)
oldblackcrow
by oldblackcrow on Sun May 02, 2021 8:28 am
Any ideas here, or a workaround? Thanks!
oldblackcrow
by jerryn on Sun May 02, 2021 1:21 pm
I tried your code on my PyPortal -- and it works as expected.
A few observations --
in your code, you are using D4 for the neopixel, but you picture show it on D3.
In your code, you define pixel_pin twice -- the second one will be the one used, but just wanted t point it out.
in your photo, it does not look like either 3V or 5V is selected ( I don't see a solder bridge to either pad).
I have mine on 5V.
jerryn
by oldblackcrow on Sun May 02, 2021 5:21 pm
Thanks @jerryn!
I believe it was the 3v trace not being connected. I am using a second PyPortal Pynt with the trace soldered proper. Also, I did comment out that first pixel_pin.
However, just so you know, on the Pynt, the D3 and D4 are mismarked and so D3 is D4 and vice versa.
Thanks again!
oldblackcrow
