LCD Shield Not working
by philippereira on Wed Apr 21, 2021 8:25 pm
I am having trouble with
RGB LCD Shield Kit w/ 16x2 Character Display - Only 2 pins used! - NEGATIVE DISPLAY
PRODUCT ID: 714
from your website. I am trying to run your "hello world" code from your libraries and nothing turns on.
Please let me know what I am doing wrong. I have attached images, hopefully they are clear. Thank you
philippereira
Re: LCD Shield Not working
by philippereira on Wed Apr 21, 2021 8:26 pm
I know the A4 wire is not plugged in, this was just for the image. It should be next to A5
philippereira
by adafruit_support_bill on Wed Apr 21, 2021 8:43 pm
Your connections do not appear to be soldered. You need to have solid electrical connectivity to the shield.
by philippereira on Sat Apr 24, 2021 11:42 am
Hi, the LCD is soldered, and nothing turns on
philippereira
by adafruit_support_bill on Sat Apr 24, 2021 1:21 pm
The solder in you joints has not flowed onto the solder pads, so they will not make reliable electrical contact.
Ideally your solder joints should have a cross section as in the diagram below. For tips on identifying and fixing common soldering problems, see this guide:
https://learn.adafruit.com/adafruit-gui ... n-problems
by philippereira on Sat Apr 24, 2021 1:43 pm
Hi, thank you. The LCD turns on but now no text is displayed after running the hello world.
philippereira
by adafruit_support_bill on Sat Apr 24, 2021 1:50 pm
Please post a new photo of the back side of the board also.
by philippereira on Sat Apr 24, 2021 2:22 pm
Here you go
philippereira
by adafruit_support_bill on Sat Apr 24, 2021 2:28 pm
That is an improvement, but there are still quite a few solder joints that have not flowed substantially onto the solder pads. In particular, most of the display header pins need more work.
by philippereira on Sat Apr 24, 2021 2:29 pm
Do you think you can point out which ones in particular? By circling them or something? Thank you
philippereira
by adafruit_support_bill on Sat Apr 24, 2021 3:20 pm
Just about all of them:
Screenshot 2021-04-24 151430.png (964.07 KiB) Viewed 272 times
by philippereira on Sat May 01, 2021 2:28 pm
Hi thanks for the response. The LCD backlight and text appear to work but the buttons do not work now. They were working at one point however. Do those solders need work? Thanks
philippereira
by adafruit_support_bill on Sat May 01, 2021 2:37 pm
Looks like some of those could use some re-work also. If you can see the gold color of the solder pad, that means the solder has not completely flowed onto it.
by philippereira on Wed May 05, 2021 4:56 pm
Hi. I have a few more questions.
I've been trying this code sent below. If I leave it in the void loop the display bugs out and the letters keep flashing but if I put it in the void set up the buttons don’t do anything. I think it’s because in the loop it is continuously checking if the buttons are pressed but that in the set up it only does it once so that I am technically “missing” the moment it checks and pushing the button after it’s already checked. It also seems that the hello world code works in the void loop but not the void setup. Can you explain what is happening. Thanks
#include <Wire.h>
//#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
int LCD_1 = A5; //??
int LCD_2 = A4; //??
// These #defines make it easy to set the backlight color
#define OFF 0x0
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
  // put your setup code here, to run once:
  // put your main code here, to run repeatedly:
lcd.begin(16, 2); //Sets the number of columns and rows on the lcd, this what the LCD is capable of
  //int Comp_Type = First;
  //int Test_Type = First;
lcd.setCursor(0, 0); //set cursor to first row
          lcd.print("Component Type?"); //prints on the first row
          lcd.setCursor(0, 1); //Set cursor to second row
          lcd.print("U:CVT L:DS R:GB"); //prints on the second row
          uint8_t buttons = lcd.readButtons();
          Serial.println("1");
  if (buttons) {
    //Now what type of test?
    if (buttons & BUTTON_UP) {
        //HERE COMPONENET IS CVT (1)
       // Comp_Type = 1;
        lcd.print("Select Test Type");
        lcd.print("U:TOP SPEED D:CYC.");
      if (buttons & BUTTON_LEFT) {
        //HERE COMPONENT IS DRIVE SHAFT
        //Comp_Type = 2;
      if (buttons & BUTTON_RIGHT) {
        //HERE COMPONENT IS GEARBOX
        //Comp_Type = 3;
    } //END OF FIRST IF STATEMENT
Last edited by adafruit_support_bill on Thu May 06, 2021 6:56 am, edited 1 time in total.
Reason: Pleas use [code] tags when posting code to the forums
philippereira
by adafruit_support_bill on Thu May 06, 2021 7:03 am
I'm not sure what you intended the code to do. But the following lines of code probably belong in setup().
The lcd.begin() initializes the display. that only needs to be done once.
And the next few lines are will continually write the same thing to the display if they are in the loop.
