PA1010D Location Issue
by DDDDDSSSSS on Thu Apr 22, 2021 11:30 am
My PA1010D is not giving the proper longitude and latitude readout. It is always wrong I have tried many locations that are miles apart. Is there any way to fix this? I am using the Adafruit Parsing code.
DDDDDSSSSS
Re: PA1010D Location Issue
by adafruit_support_carter on Thu Apr 22, 2021 2:58 pm
Are you using just the parsing code? Or are you running one of the examples from the library?
by DDDDDSSSSS on Thu Apr 22, 2021 7:38 pm
I am using the library examples I first ran the echo test and now the parsing code. I am getting locked onto 12-13 satellites at a given time but still, the longitude and latitude are very off.
DDDDDSSSSS
by adafruit_support_carter on Fri Apr 23, 2021 3:37 pm
Please link to the specific sketch you are running. There are several related to parsing.
https://github.com/adafruit/Adafruit_GP ... r/examples
by DDDDDSSSSS on Fri Apr 23, 2021 3:42 pm
This is the code:
https://github.com/adafruit/Adafruit_GP ... arsing.ino
I am using Software Serial
DDDDDSSSSS
by adafruit_support_carter on Fri Apr 23, 2021 4:06 pm
Thanks. And you've wired per the connection diagram here?
https://learn.adafruit.com/adafruit-min ... uart-usage
Does the other information seem OK? It's just lat/lon that are off?
by DDDDDSSSSS on Fri Apr 23, 2021 4:09 pm
I have wired per the diagram. For my project, the only information that I am using is the Latitude and Longitude which are not right. I do know that the date and time are off but I did not check anything else.
DDDDDSSSSS
by adafruit_support_carter on Mon Apr 26, 2021 11:35 am
Look at the other information as well. That way you can verify you have a fix and the quality of the fix.
