DRV8871 Brushed DC Motor Driver Breakout Not Working
by jbettis on Thu May 13, 2021 1:50 pm
I recently purchased the DRV8871 DC Motor Driver board, but when I went to use it, it did not appear to be working.
This is the code I used (which I got from https://learn.adafruit.com/adafruit-drv8871-brushed-dc-motor-driver-breakout/usage):
// Basic sketch for trying out the Adafruit DRV8871 Breakout
#define MOTOR_IN1 9
#define MOTOR_IN2 10
  Serial.begin(9600);
  Serial.println("DRV8871 test");
  pinMode(MOTOR_IN1, OUTPUT);
  pinMode(MOTOR_IN2, OUTPUT);
  // ramp up forward
  digitalWrite(MOTOR_IN1, LOW);
  for (int i=0; i<255; i++) {
    analogWrite(MOTOR_IN2, i);
    delay(10);
  // forward full speed for one second
  delay(1000);
  // ramp down forward
  for (int i=255; i>=0; i--) {
    delay(10);
  // ramp up backward
  digitalWrite(MOTOR_IN2, LOW);
    analogWrite(MOTOR_IN1, i);
    delay(10);
  // backward full speed for one second
  delay(1000);
  // ramp down backward
    delay(10);
Using a multimeter, I watched the voltages on both of the input pins, and saw them ramping up and down as expected. I also checked the voltage across the power pins, which I saw had about 5V across them. However, there was no voltage across the motor, which was not spinning. The Arduino used is the Arduino Uno.
Is the motor driver defective, or am I doing something wrong?
This is a picture of the wiring:
Wiring:
IMG_20210513_113252923 (1) (1).jpg (115.92 KiB) Viewed 358 times
jbettis
Re: DRV8871 Brushed DC Motor Driver Breakout Not Working
by adafruit_support_bill on Thu May 13, 2021 1:54 pm
What were you using to power the UNO?
by jbettis on Thu May 13, 2021 2:39 pm
I had it plugged into my laptop.
jbettis
by adafruit_support_bill on Thu May 13, 2021 2:41 pm
When powered via the USB jack, the only current available on the VIN pin is what ever leaks backwards through the voltage regulator. Move your red VM jumper to the 5v pin to get full USB power.
by jbettis on Thu May 13, 2021 2:49 pm
I tried that. It still didn't work.
jbettis
by adafruit_support_bill on Thu May 13, 2021 3:17 pm
Please post some photos showing your soldering on the board.
by jbettis on Thu May 13, 2021 3:45 pm
Here are some photos of the soldering. None of the pins are visibly soldered together.
IMG_20210513_133543085 (1).jpg (332.67 KiB) Viewed 353 times
IMG_20210513_133511348 (1).jpg (332.7 KiB) Viewed 353 times
IMG_20210513_133427177 (1).jpg (373.16 KiB) Viewed 353 times
jbettis
by adafruit_support_bill on Thu May 13, 2021 3:48 pm
That all looks good. We can try replacing the board. Please contact support@adafruit.com with a link to this thread.
by bucc5062 on Sat Jul 17, 2021 8:19 pm
I had the same issue where I soldered the board clean (had it checked by someone who knows), wired it up and yet I dwid not see any voltage change when I ran the same program. I also checked that the board was getting power from the arduino (5V), but nothing on the motor side.
I will try another (I bought two), but I am wondering if I'm still not doing something right.
bucc5062
