I am currently working on a project that calls for reading the power draw on a motor and displaying other information on an OLED, with the Heltec ESP32 Wifi Kit. I have ran into the
problem that when my OLED display is running that the INA 260 outputs in the serial a maximum number that is not a correct reading (Serial Print output: 4294967296.00,mW
5368709120.00,mV -1.25,mA), but the OLED displays the information perfectly fine. However, when I comment out the code for the OLED the INA 260 output is correct.
I am curious if the OLED library I am using may be causing issues with the INA 260's readings (the heltec.h library :
https://github.com/HelTecAutomation/Hel ... r/examples) or if there is something I need to add to my code in order to make the INA 260 work with the OLED on
the Heltec ESP32 Wifi Kit. Below will be the rewritten code showing only the OLED and INA 260 code, in order to get a better understanding of just that problem.
#include "sensorModule.h"
#include "oledDisplay.h"
#include "oledNewFonts.h"
int testCycleCounter = 0;
//Object pointers
SensorModule *sensorModule;
OledDisplay *thisDisplay;
void setup()
Serial.begin(115200);
* Set up sensors
sensorModule = new SensorModule();
thisDisplay = new OledDisplay();
//Initialize the display
thisDisplay->DisplaySetup();
delay(1000);
void loop()
thisDisplay->TestDisplayMode(); //Update the display of the oled
sensorModule->Update(); //Update INA260 sensor (timer is internal to SensorModule object)
delay(100);
testCycleCounter++;
String _cycleCount;
String _currentMode;
String _cycleTiming;
String _sensorData;
extern int testCycleCounter;
//The global variables for ongoing test data
OledDisplay::OledDisplay()
this->_maxTime = 10;
OledDisplay::~OledDisplay()
void OledDisplay::DisplaySetup()
Heltec.begin(true, false, false);
Heltec.display->flipScreenVertically();
Heltec.display->setFont(ArialMT_Plain_10);
this->ScreenClear();
void OledDisplay::DefaultDisplayWrite()
Heltec.display->setTextAlignment(TEXT_ALIGN_LEFT); //Align Text to the left
Heltec.display->drawString (0, 0, "Cycle Default: " + String(DEFAULT_TARGET_TEST_CYCLE_COUNT));
Heltec.display->drawString (0, 10, "Start Delay Default: " + String(DEFAULT_TEST_START_DELAY_TIME));
Heltec.display->drawString (0, 20, "Raise Time Default: " + String(DEFAULT_TEST_RAISE_TIME));
Heltec.display->drawString (0, 30, "Pause1 Time Default: " + String(DEFAULT_TEST_PAUSE_1_TIME));
Heltec.display->drawString (0, 40, "Lower Time Default: " + String(DEFAULT_TEST_LOWER_TIME));
Heltec.display->display();
void OledDisplay::TestDisplayWrite()
Heltec.display->setFont(ArialMT_Plain_16);
Heltec.display->drawString (0, 33, "Cyc: " + String(testCycleCounter));
void OledDisplay::ScreenClear()
Heltec.display->clear();
void OledDisplay::TestDisplayMode()
ScreenClear();
TestDisplayWrite();
SensorModule::SensorModule()
this->_delayTime = INA260_DELAY_TIME;
this->_lastVoltage = 0;
this->_lastCurrent = 0;
this->_lastPower = 0;
// Set up INA260 sensor
this->ina260 = new Adafruit_INA260();
this->ina260->begin();
this->ina260->setAveragingCount(INA260_COUNT_4); // Set the number of samples to average
this->ina260->setVoltageConversionTime(INA260_TIME_140_us); // Set the time over which to measure the current and bus voltage
this->ina260->setCurrentConversionTime(INA260_TIME_140_us); // Set the time over which to measure the current and bus voltage
this->ina260->setMode(INA260_MODE_CONTINUOUS);
this->ina260PreviousReadTime = 0;
SensorModule::~SensorModule() {}
void SensorModule::Update()
unsigned long currentTime = millis();
if ((currentTime - this->ina260PreviousReadTime) >= INA260_DELAY_TIME)
this->UpdateCurrent();
this->UpdateVoltage();
this->UpdatePower();
this->ina260PreviousReadTime = currentTime;
this->PublishCurrentValues();
void SensorModule::UpdateCurrent()
this->_lastCurrent = this->ina260->readCurrent();
void SensorModule::UpdateVoltage()
this->_lastVoltage = this->ina260->readBusVoltage();
void SensorModule::UpdatePower()
this->_lastPower = this->ina260->readPower();
void SensorModule::PublishCurrentValues()
if (Serial)
Serial.println("ComboCVP:" + String(this->_lastPower) + ",mW,"
+ String(this->_lastVoltage) + ",mV,"
+ String(this->_lastCurrent) + ",mA,");
