How can I set the SPI address for the Adafruit iMAX31865 RTD
by bmihura on Mon Jun 14, 2021 12:07 pm
I want to connect three of these to one Arduino, but I don't see how I can set their SPI address.
bmihura
Re: How can I set the SPI address for the Adafruit iMAX31865
by adafruit_support_carter on Mon Jun 14, 2021 12:10 pm
SPI does not uses addresses. Instead, each device needs a dedicated Chip Select (CS) pin. The CLK, SDO, and SDI pins would be shared.
The pins used for CS can just be any available GPIO pins.
by bmihura on Mon Jun 14, 2021 4:30 pm
Thanks, that makes sense.
bmihura
by adafruit_support_carter on Mon Jun 14, 2021 5:40 pm
Sure. No prob. I2C on the other hand does use addresses. I2C has shared clock (SCL) and data (SDA) lines. Each device on the I2C bus needs to have a unique address.
