I have been working on a project and wanted to use the slim optical fingerprint sensor to protect it. I got my order in from Adafruit and started out on the fingerprint sensor. I followed the guide that was posted on the Adafruit website even though the tutorial and wiring diagram was showing the bigger finger print sensor. I thought that the code and wires might be the same so I went on and plugged in the wires and ran the enroll code provided in the Adafruit Fingerprint library.
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
products from Adafruit!
BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
uint8_t id;
void setup()
Serial.begin(9600);
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit Fingerprint sensor enrollment");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
} else {
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
Serial.println(F("Reading sensor parameters"));
finger.getParameters();
Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
Serial.print(F("Security level: ")); Serial.println(finger.security_level);
Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
uint8_t readnumber(void) {
uint8_t num = 0;
while (num == 0) {
while (! Serial.available());
num = Serial.parseInt();
return num;
void loop() // run over and over again
Serial.println("Ready to enroll a fingerprint!");
Serial.println("Please type in the ID # (from 1 to 127) you want to save this finger as...");
id = readnumber();
if (id == 0) {// ID #0 not allowed, try again!
return;
Serial.print("Enrolling ID #");
Serial.println(id);
while (! getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
int p = -1;
Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
break;
case FINGERPRINT_NOFINGER:
Serial.println(".");
break;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
break;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
break;
default:
Serial.println("Unknown error");
break;
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
break;
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID "); Serial.println(id);
p = -1;
Serial.println("Place same finger again");
switch (p) {
break;
Serial.print(".");
break;
break;
break;
default:
break;
// OK success!
p = finger.image2Tz(2);
switch (p) {
break;
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #"); Serial.println(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
} else {
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
} else {
return p;
return true;
And the video tutorial I was following https://www.youtube.com/watch?v=1diFaa5OsFg
And this sensor I am using https://www.adafruit.com/product/4750
Also, while compiling, the error messages said
/Users/ethan/Documents/Arduino/libraries/Adafruit_Fingerprint_Sensor_Library/Adafruit_Fingerprint.cpp: In member function 'uint8_t Adafruit_Fingerprint::setPassword(uint32_t)':
/Users/ethan/Documents/Arduino/libraries/Adafruit_Fingerprint_Sensor_Library/Adafruit_Fingerprint.cpp:415:54: warning: narrowing conversion of '(password >> 24)' from 'uint32_t {aka long unsigned int}' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
SEND_CMD_PACKET(FINGERPRINT_SETPASSWORD, (password >> 24), (password >> 16),
/Users/ethan/Documents/Arduino/libraries/Adafruit_Fingerprint_Sensor_Library/Adafruit_Fingerprint.cpp:37:21: note: in definition of macro 'GET_CMD_PACKET'
uint8_t data[] = {__VA_ARGS__}; \
/Users/ethan/Documents/Arduino/libraries/Adafruit_Fingerprint_Sensor_Library/Adafruit_Fingerprint.cpp:415:3: note: in expansion of macro 'SEND_CMD_PACKET'
/Users/ethan/Documents/Arduino/libraries/Adafruit_Fingerprint_Sensor_Library/Adafruit_Fingerprint.cpp:415:72: warning: narrowing conversion of '(password >> 16)' from 'uint32_t {aka long unsigned int}' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
/Users/ethan/Documents/Arduino/libraries/Adafruit_Fingerprint_Sensor_Library/Adafruit_Fingerprint.cpp:416:29: warning: narrowing conversion of '(password >> 8)' from 'uint32_t {aka long unsigned int}' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
(password >> 8), password);
/Users/ethan/Documents/Arduino/libraries/Adafruit_Fingerprint_Sensor_Library/Adafruit_Fingerprint.cpp:37:32: warning: narrowing conversion of 'password' from 'uint32_t {aka long unsigned int}' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
/Users/ethan/Documents/Arduino/libraries/Adafruit_Fingerprint_Sensor_Library/Adafruit_Fingerprint.cpp:50:3: note: in expansion of macro 'GET_CMD_PACKET'
GET_CMD_PACKET(__VA_ARGS__); \
/Users/Ethan/Documents/Arduino/libraries/Adafruit_Fingerprint_Sensor_Library/Adafruit_Fingerprint.cpp:415:3: note: in expansion of macro 'SEND_CMD_PACKET'
After trying everything I could, I kept getting this message.
If anybody knows how to fix this with code or wiring, please help me.
Thank You
